2 Pages<12
#21 Posted : Tuesday, 8 March 2016 5:03:47 PM(UTC)
The 1969 Carter carbs are very different. I'll send you pictures of one if you PM me your email address.
gm5735 Offline
#22 Posted : Tuesday, 8 March 2016 5:14:54 PM(UTC)
gm5735
Done
benny Offline
#23 Posted : Wednesday, 13 July 2016 5:40:26 PM(UTC)
benny
the carby we have found is a 29283 date code 0159 do you think this would be correct or is it supposed to have the zc in there as well, many thanks benny..
#24 Posted : Thursday, 14 July 2016 7:11:05 AM(UTC)
That is right for a very early HT GTS350 manual. Later cars have a different format.
benny Offline
#25 Posted : Thursday, 14 July 2016 9:18:18 AM(UTC)
benny
its 3rd week of November 1969..
#26 Posted : Thursday, 14 July 2016 9:59:41 AM(UTC)
That is not an early HT GTS350. Early is pre release production or the first few hundred cars. What you'd be looking for is the 3rd type I mentioned in post #7 of this thread.
Edited by user Thursday, 14 July 2016 10:02:03 AM(UTC)  | Reason: Not specified
benny Offline
#27 Posted : Thursday, 14 July 2016 11:51:39 AM(UTC)
benny
ok thanks for clearing that up..i have someone who has a 327 but the stamping of the engine number is a bit up and down so I am a bit dubious of buying it ..did they stamp them roughly sometimes or should it be in a straight line..it is 32742379 not sure if date code matches it is T1121H5, there is a date on back of block J207.. heads have K157... inlet J307 of course the carby is missing as per normal..do you think all these numbers correspond, has correct casting numbers on heads and block for early 327..thanks again, your wealth of knowledge on these cars is a big help to me and I am making notes of a lot of this stuff I am learning for future reference, cheers benny..
#28 Posted : Thursday, 14 July 2016 5:15:52 PM(UTC)
Some were rough, but that is not a GTS327 engine number so it has been made up by someone.
benny Offline
#29 Posted : Thursday, 14 July 2016 5:31:44 PM(UTC)
benny
should be 78 on the end not 79, just cleaned it up with a bit of sandpaper..probably doesn't make a difference by the sound of it, and explains why it is stamped a bit here and there..thanks..
Edited by user Thursday, 14 July 2016 5:49:32 PM(UTC)  | Reason: Not specified
camaroTT400 Offline
#30 Posted : Tuesday, 10 August 2021 7:32:02 PM(UTC)
camaroTT400
Just found a 29283 0159 been sitting on a farm the last 40 odd years. Would this be for an early HT 350M ??
#31 Posted : Tuesday, 10 August 2021 7:49:48 PM(UTC)
Yes. I have the same carby here. We know that the first HT GTS350 had a HK carby (same carby just stamped differently), the Verdoro Pagewood 1-H5 car. However they must have only a few remaining and that carby you have would have been used on maybe the next maybe 100 cars give or take.
camaroTT400 on 10/08/2021(UTC)
camaroTT400 Offline
#32 Posted : Tuesday, 10 August 2021 8:50:11 PM(UTC)
camaroTT400
would you know roughly what months in 69 this carb would have been on.
#33 Posted : Tuesday, 10 August 2021 9:06:54 PM(UTC)
The first cars. Not sure what that means in months, but remember they built lots of cars for release.
camaroTT400 Offline
#34 Posted : Tuesday, 10 August 2021 9:35:56 PM(UTC)
camaroTT400
Ok that makes sense, thanks heaps for your help.
benny Offline
#35 Posted : Wednesday, 11 August 2021 7:28:13 AM(UTC)
benny
hi camaro tt400, i would be interested in that carby, if you want to sell it for my late hk 327, thanks
#36 Posted : Wednesday, 11 August 2021 8:18:33 AM(UTC)
Doesn’t suit HK, only HT.
benny Offline
#37 Posted : Wednesday, 11 August 2021 11:00:53 AM(UTC)
benny
ahhh bugger so i need a 7029283,, i think my car is august 69 hk 327
#38 Posted : Wednesday, 11 August 2021 11:52:21 AM(UTC)
August 1969 is HT.
You need the straight 7029283 if your HK has the Canadian 327 and after December 1968. In my experience the hardest GMH Quadrajet to find.
benny Offline
#39 Posted : Wednesday, 11 August 2021 5:57:00 PM(UTC)
benny
sorry registered august 69, i think its build 230 adelaide second series of cars
Monaro23D Offline
#40 Posted : Monday, 16 August 2021 8:05:30 PM(UTC)
Monaro23D
Currently on Ebay https://www.ebay.com.au/...m=&item=255101108746
Edited by user Saturday, 21 August 2021 8:26:52 AM(UTC)  | Reason: Not specified
Monaro HK 327 GTS
2 Pages<12
