panoman Offline
#1 Posted : Sunday, 20 March 2016 11:54:47 AM(UTC)
panoman
Hello, I just had the diff cover off what I believe is a small Salisbury diff which is sitting under my HG Panelvan.
was just changing the gasket, but wanted to confirm the ratio whilst cover off. It is stamped on the crown gear as 2.78 however
I also found an area on the gear that had been ground and engraved with the numbers 76381-11 was just wondering if anyone on the
forum would have any idea want that number might mean.
the other factory stamp reads "HOLDEN 7435268 - 2.78 RATIO MD"
is HOLDEN 7435268 a part number as I don't seem to come up with anything on Google.
I was going to attach a picture of the area but cant find the attach checkbox
Cheers and thanks Mick
Edited by user Sunday, 20 March 2016 12:12:54 PM(UTC)  | Reason: add picture
castellan Offline
#2 Posted : Sunday, 20 March 2016 12:58:03 PM(UTC)
castellan
looks like a small one to me.
gm5735 Offline
#3 Posted : Monday, 21 March 2016 12:48:56 PM(UTC)
gm5735
The engraved number is the serial number for that crown wheel, and the dash number is probably the pinion shim depth. There will probably be a matching number on the pinion somewhere, as they were matched in pairs and lapped together.
For that reason you will probably find that the 7435268 number will not come up in normal listings as it wasn't serviced separately - only as a set with a matching pinion.
panoman Offline
#4 Posted : Tuesday, 22 March 2016 7:23:40 AM(UTC)
panoman
Ok, thankyou for that information. that sounds logical.
cheers Mick
