Hk186p Offline
#1 Posted : Friday, 29 April 2016 5:21:00 PM(UTC)
Hk186p
Hi I also have a Hk 307 chev i would also like someone to tell me where its from what plant month and year thank you number is 30790417 k10 23
#2 Posted : Friday, 29 April 2016 6:51:58 PM(UTC)
Mosman Park (Perth) assembled HK or HT.
Hk186p Offline
#3 Posted : Friday, 29 April 2016 7:35:48 PM(UTC)
Hk186p
Thanks HK1837 what month and year 69 or 70 Prem Monaro or Brom?
#4 Posted : Friday, 29 April 2016 8:16:24 PM(UTC)
No idea. Mosman park V8's are not common, so could even be into HT, but will be 1968 or 1969. It is the 418th 307/327 stamped there. Not just Premier, Monaro or Brougham. Could also be Belmont, Kingswood or GTS. Not sure if Mosman Park even assembled Brougham or GTS. The engine was assembled on 23rd October 1967.
Hk186p Offline
#5 Posted : Friday, 29 April 2016 9:51:14 PM(UTC)
Hk186p
Thanks Hk1837 that's the info i was after.
detective Offline
#6 Posted : Saturday, 30 April 2016 9:42:16 AM(UTC)
detective
...is K10 23 a date code ?
#7 Posted : Saturday, 30 April 2016 10:49:05 AM(UTC)
K means McKinnon Industries, later St Catharine's. 10 is October. 23 is 23rd. This is the engine assembly plant and assembly date/month code.
Hk186p Offline
#8 Posted : Saturday, 30 April 2016 8:06:24 PM(UTC)
Hk186p
Hi Hk1837 what would this engine be worth its a good runner putting it in my Hk Premier its not the original engine it was a 186 but i have a Perth built car regards Hk186p.
detective Offline
#9 Posted : Saturday, 30 April 2016 8:36:56 PM(UTC)
detective
Thanks Byron .. could you please de-cipher the HQ GTS350 engine number QU40113 KO303H as fitted to my 8/1971 coupe ? (and please also excuse me for being a tad off topic)
#10 Posted : Saturday, 30 April 2016 8:57:26 PM(UTC)
The accessories on the engine are worth more than the actual block and heads. Air cleaner, carby, exhaust manifolds, sump, dizzy etc. If it is a good runner and complete maybe $1000-$1500, something around that.
#11 Posted : Saturday, 30 April 2016 9:03:57 PM(UTC)
You already know the QU bit.
40113 is the 114th Dandenong assembly plant stamped HQ GTS350 engine.
K is General Motors of Canada, St Catharine's (the Canadian engine plant).
O303 is 3rd March (1971 - you need the cast date off the side of the block to give you the year).
H exact meaning is subject to some conjecture, but it essentially means Holden - you'll find this on all HK, HG and HQ McKinnon/St Catharine's assembled engines other than for 307.
detective Offline
#12 Posted : Saturday, 30 April 2016 9:08:27 PM(UTC)
detective
..bloody amazing stuff .. you guys are good ! and thank you
Hk186p Offline
#13 Posted : Saturday, 30 April 2016 9:25:49 PM(UTC)
Hk186p
Thanks Hk1837 all the best.
#14 Posted : Tuesday, 3 May 2016 9:58:55 AM(UTC)
Ben reckons the Mosman Park 307 will be from a HT - it is the latest 307 from there that he has seen. Shows you how few 307 powered HK Mosman park assembled.
Hk186p Offline
#15 Posted : Tuesday, 3 May 2016 11:21:31 PM(UTC)
Hk186p
Hk1837 that will be a good engine number for my car its a late 69 Build Hk Premier good to know thanks.
#16 Posted : Wednesday, 4 May 2016 6:57:25 AM(UTC)
Yes, would be reasonably OK as long as the Premier is a Mosman Park car.
Hk186p Offline
#17 Posted : Wednesday, 4 May 2016 6:39:56 PM(UTC)
Hk186p
The car has 6L on the skinny tag making it a Perth car so it should be alright thanks mate.
