Matty Q Offline
#1 Posted : Wednesday, 27 April 2016 7:13:27 PM(UTC)
Matty Q
Hi all
I have a question around the noise suppression capacitors fitted to the coil and alternator on the older (maybe pre mid-80's?) Holdens. I went to purchase them recently for my HJ and found them nigh impossible to buy - generally people only sell the distributor condensor.
My general understanding is the suppression capacitors, fitted to the "line" side of the coil and the output of the alternator, were intended primarily (solely?) as a means for reducing RF (Radio Frequency) noise in the radio, specifically the AM band. (Other advancements in the very early days included type of spark-plug leads used, for instance, but put that aside). In comparison, the role of the condensor (though also a capacitor) in the distributor was to absorb energy caused by the back-EMF from the collapsing field in the ignition coil so as not to burn out the distributor contact points.
So, questions:
1. What are the relative values (uF and Voltage) of the distributor condensor capacitor vs. the noise suppression capacitors - in my case, a HJ Caprice with 308 V8?
2. Why were they phased out? I can only assume there are multiple reasons - advancement in RF noise suppression (both source reduction and better suppression techniques), change in ignition systems, few people using original A/M radios, etc.?
3. If one was hell-bent on re-fitting the original noise suppression capacitors to the coil and alternator (e.g., for originality), where can they be sourced?
Thanks in advance.
Continually amazing how people are willing to share information.
#2 Posted : Wednesday, 27 April 2016 9:56:42 PM(UTC)
Good question, this one is seriously testing my memory.
There isn't a lot of difference in the relative capacitance values of the points condenser vs the suppression condenser. Probably the biggest difference would be temperature & peak voltage specs.
Most points condensers are around .22 uF to .25 uF, but the voltage rating would be a lot higher than just 12V due to the back EMF of the ignition coil & the necessary temperature rating would be likewise high for longevity.
Most suppression condensers are around .47 uF, but their voltage & temperature requirements are lower than the points condenser.
If you live in country areas & use an AM radio, suppression requirements just are as important as they ever were. Sure there have been huge improvements in ignition system design, HT leads & alternator design, but AM radios have gone backwards big time.
If you still have an AM radio noise issue & you are sure that the antenna has a good earth, then some suppressors may be required. It really depends if you are suffering from ignition noise crackle or alternator whine (usually fairly easy to pick) just fit the suppressors required.
While they are more difficult to buy than in years past, you can purchase them from WES Components (Ashfield, Sydney) under part no.CNS2, they are only a few $ each.
#3 Posted : Thursday, 28 April 2016 7:54:24 AM(UTC)
On further investigation, it seems that these suppression capacitors do vary from brand to brand & I guess from country to country.
I checked some old ones I had in the workshop & they vary from .47uF to as high as 2.2uF. Most seem to be .47uF or 1uF.
I would imagine the larger the capacitor, then more the it kills the RF noise. It probably also depends on the noise source & its frequency.
The frequencies involved are all fairly low. e.g. ignition noise @ 2000 rpm in a 6-cyl only 100 Hz & an alternator would be similar. An old DC generator (dynamo) would be higher but only by a factor of 4 or 5 times, depending on how many segments there are on the commutator & the pulley ratio.
If you are having noise issues with your car's audio system, another method commonly seen these days is to fit an inductive choke into the 12V supply line to the radio/CD/amp or whatever.
Edited by user Thursday, 28 April 2016 7:59:25 AM(UTC)  | Reason: Not specified
#4 Posted : Thursday, 28 April 2016 8:24:15 AM(UTC)
The biggest issue I have with AM today is HV overhead line discharge (corona) especially if it very humid or light rain. AM radios are and have always been very good tools in detection of partial discharge in HV switchgear. By design overhead lines have built in partial discharge across the insulators, hence why your AM radio detects it whenever you drive near OH lines. It always annoys me when I'm driving up the New England Highway between Singleton and Muswellbrook listening to the Cricket or the Footy on 1233.
As Dr Terry says good question though, never really worried too much about it as I've always fitted a modern stereo unit other than my old '57 Chevy which had an original late 1950's, early 1960's AM radio, but it was crackly anyway due to the copper wire antenna run around the inside of the windscreen which was a pretty poor antenna installation.
gm5735 Offline
#5 Posted : Thursday, 28 April 2016 10:10:31 AM(UTC)
gm5735
Tuned in to Radio 2 picoCoulomb?
I did some work with the State Electricity Commission and a University here years ago, with a very directional microphone mounted on a crossbow with a telescopic sight as a means of identifying the source of the discharge. On several occasions the police took some convincing that no one was going to be shot.
#6 Posted : Thursday, 28 April 2016 10:33:49 AM(UTC)
We use to walk into a HV switchroom at the Steelworks with a portable AM radio. Doesn't matter what station its on. Gives you a ballpark comparison between HV switchboards and could even help identify which panel. Of course to figure out exactly where it's coming from you needed more specialised gear but it was/is a very good indicator.
gm5735 Offline
#7 Posted : Thursday, 28 April 2016 10:36:28 AM(UTC)
gm5735
The points switch at 100Hz, but the arc is at the resonant frequency of the coil and the capacitor, at least until the points are fully open. For coil primary inductances of around 4mH and capacitors of around 0.2uF this would be around 5kHz, with plenty of harmonics.
For HKTG vintage stuff, if the alternator is the Bosch type, there are points in the voltage regulator that switch the field supply at a high frequency, and are quite noisy. The Lucas voltage regulators are solid state and do not as generate as much RFI.
I saw a comment about plug leads in the initial post. Although they are often called "Suppression" leads, and contain a carbon string inner with significant resistance, one of the main functions of the resistive plug leads is to limit current fed to the plug and increase the duration of the spark when the plug fires. A solid wire plug lead causes the spark to quench too quickly.
There is some benefit for RFI reduction, but they are needed for the current limiting effect.
Matty Q Offline
#8 Posted : Friday, 29 April 2016 10:07:04 AM(UTC)
Matty Q
Thanks Terry, that all makes good sense. As do the other replies - although that is external RF interference, and another matter.
griffo Offline
#9 Posted : Monday, 9 May 2016 6:21:11 AM(UTC)
griffo
http://www.ebay.com.au/i...3eccf03:g:-QIAAOSwQJhUgp~V
http://www.ebay.com.au/i...40321:g:RTcAAOxyOM5RZqw1
Some on Ebay....Cheers
Edited by user Monday, 9 May 2016 6:33:44 AM(UTC)  | Reason: Not specified
Matty Q Offline
#10 Posted : Monday, 9 May 2016 7:10:17 PM(UTC)
Matty Q
Great, thanks Griffo - good find!
