Jul71-Oct74 Offline
#1 Posted : Thursday, 30 June 2016 10:47:13 PM(UTC)
Jul71-Oct74
Hi Guys
Can anyone tell me what the ACTUAL physical differences are between a 202 head stamped 2811930 and a 9937262 one. I know one is an adr27a head, but what is the technical difference?
Rick
#2 Posted : Friday, 1 July 2016 10:16:43 AM(UTC)
Pollution one has a threaded boss on the driver's side for the thermal switch. The thermal switch is in series with the switch on the 3 or 4 speed top gear selector or on the back of a trimatic. When the vehicle is in top gear and warmed up these two switches connect the vacuum solenoid up on the motor to the 0V terminal of the battery (via the body), so the solenoid operates and allows full vacuum to the distributor. I think this is the only difference. When I put a Yella Terra 186 head on the 202 in my WB tonner, I put a little angled metal bracket hanging off one of the rocker cover bolts that held the switch in roughly the right place, and soldered a little bridge across the terminals under the switch. In my case the Trimatic in it was an early one so I just put the wire at that end into a ring lug and under a gearbox pan bolt. That way the solenoid was always on, and the dizzy got vacuum advance all the time.
#3 Posted : Friday, 1 July 2016 10:17:29 AM(UTC)
I don't believe that there was much difference in the combustion chamber or port shape, but there were changes made to allow attachment of the various ADR27A sensors.
There was an extra boss near No 2 spark plug for the cold feed temp switch, which was part of the vacuum advance inhibitor circuit. The was also the 2 extra threaded holes into the water jacket on the carby side of the head. These were for the EGR & EFE vacuum switches.
Apart from these minor differences, AFAIK the 2 heads are interchangeable for all practical purposes.
Jul71-Oct74 Offline
#4 Posted : Saturday, 2 July 2016 6:26:35 AM(UTC)
Jul71-Oct74
Thanks for the information fellas.
