Ausjacko Offline
#1 Posted : Monday, 18 July 2016 10:58:06 PM(UTC)
Ausjacko
Hi All
What is the consensus on when the change needle on the tacho started to appear in the Monaro; HT or HG or GTS?
Jacko
#2 Posted : Tuesday, 19 July 2016 6:51:03 AM(UTC)
Only GTS had the tacho unless you optioned it, Monaro never did unless U21 optioned. As far as i'm aware HT had the needle and HG didn't.
Ausjacko on 19/07/2016(UTC)
Ausjacko Offline
#3 Posted : Tuesday, 19 July 2016 3:49:18 PM(UTC)
Ausjacko
Thanks HK.
Had a look through the Monaro magic book. Page 59 has a photo in which you can just make out the shift needle. That car is a v8 GTS manual HT.
#4 Posted : Thursday, 22 September 2016 12:23:48 AM(UTC)
My late (6/70) HT GTS doesn't have a shift needle, which I believe may point to Holden transition to HG style in the last month or 2 of HT (the Tacho is dated 5/70). Does anyone else have the same?
