Hk186p Offline
#1 Posted : Monday, 15 August 2016 9:52:50 PM(UTC)
Hk186p
Hi does any one know the size of the Hk Holden Sway Bar to suit a 307 chev.
#2 Posted : Tuesday, 16 August 2016 9:09:56 AM(UTC)
The front sway bar for a 307 HK isn't unique to that engine.
AFAIK there are only 2 different front sway bars to suit HK. One for the GTS & the other for all others.
gm5735 Offline
#3 Posted : Tuesday, 16 August 2016 10:17:55 AM(UTC)
gm5735
There are 2 front stabiliser shafts for HK. One size is around 5/8" diameter and is for everything except GTS327. The GTS327 shaft is 15/16".
For HT and HG there are 3 types. There is the 5/8" shaft for all 6 cylinder and 307 (the same as HK), a 3/4" (approx) shaft for 253 and 308 engines, and a 15/16" shaft for 350 engines (the same as HK327). The 253/308 shaft also has a kink in it for oil filter access and bottom radiator hose clearance.
The 5/8" shaft is the correct one for all HK 307.
Hk186p Offline
#4 Posted : Wednesday, 17 August 2016 7:38:04 PM(UTC)
Hk186p
Thanks for the reply's.
This page was generated in 0.022 seconds.
