Joined: 29/04/2016(UTC) Posts: 31 ![Australia Australia]() Location: Suburbia
Hi does any one know the size of the Hk Holden Sway Bar to suit a 307 chev.
The front sway bar for a 307 HK isn't unique to that engine.
AFAIK there are only 2 different front sway bars to suit HK. One for the GTS & the other for all others.
Dr Terry |
Joined: 16/04/2014(UTC) Posts: 768  Location: Victoria Thanks: 1 times Was thanked: 49 time(s) in 47 post(s)
There are 2 front stabiliser shafts for HK. One size is around 5/8" diameter and is for everything except GTS327. The GTS327 shaft is 15/16". For HT and HG there are 3 types. There is the 5/8" shaft for all 6 cylinder and 307 (the same as HK), a 3/4" (approx) shaft for 253 and 308 engines, and a 15/16" shaft for 350 engines (the same as HK327). The 253/308 shaft also has a kink in it for oil filter access and bottom radiator hose clearance.
The 5/8" shaft is the correct one for all HK 307.
