Joined: 13/09/2016(UTC) Posts: 3 ![Australia Australia]() Location: Western Australia
Hi All after some info been offered to purchase a original 1 owner with books HQ Kingswood with sports pack upgrade has gts Monaro wheels Monaro paint Purple with(White stripped bonnet) 253 V8 column shift auto ,cream interior, bench seat ,all original front and rear louvers Vin DHQ99858M engine number QR394365 another number is 12784563 just waiting for body number now any ideas would be apreciated
Thanks: 1 times Was thanked: 629 time(s) in 592 post(s)
It should have cloth inserts in the bench seat and from memory upgraded instruments. Wheels are Rally Rims, not Monaro GTS rims. Monaro never had white on bonnet, maybe GTS sedan did. Can't recall if this was part of the Kingswood Sports pack or not. I have a brochure and ad for these cars somewhere. |
Defiantly no inserts on bench seat, must be gts bonnet then has air con ,another number is 8N69RDJ3954969 if you have a brochure that would be great really want to try get a value / estimate
Originally Posted by: Cataz355  Defiantly no inserts on bench seat, must be gts bonnet then has air con ,another number is 8N69RDJ3954969 if you have a brochure that would be great really want to try get a value / estimate What is the TRIM line on the BODY plate? It probably isn't a Kingswood Sports as these are supposed to have cloth inserts. Dr Terry has one of these cars in Saffron Metallic. If you like send me photos of the plates and i'll get them checked out. I'll see if I can find the brochure. Value wise it is like a HT White Hot Holden, the value is not that different from other similarly optioned cars and condition will dictate its value more than it being a "Sports". 8N69RDJ395496Q is the VIN not DHQ99858M, that is the chassis number. |
Model HQ80469 Body number 395496M TRIM 1856-38J Paint 568-15347 Original owner lives in Adelaide
Joined: 14/09/2016(UTC) Posts: 32 ![Australia Australia]() Location: Perth Thanks: 6 times
Are you fellas talking of a "Sports Pack" option or the limited availability "Sports Trim" option ?
Sounds like the car in question is a sort-of HQ Monaro GTS sedan clone ... it's either a 1973 or 1974 build in a colour that is not common on a Kingswood, being "Purr-Pull" and the 38J trim code references a "Doeskin" interior with black accents.
As for the "Sports Trim" option, available only in 1974, it was really just an interior dress-up package which for the most part involved hounds-tooth cloth bench seat inserts and floor carpeting.
