Hi all,
i have some Holden V8 manifolds lying around and want to sort out whats what,
Holden 4BBL 2812094 Holden 4BBL 2823087 Holden 4BBL 9929853 Holden 4BBL 9932890 Holden 4BBL no cast number, just a casting of the letter X
Holden 2BBL 2805483 Holden 2BBL 9932888 Holden 2BBL 994569? ( raised casting on the last number not the best, looks like an 8 or a 9,)
any help on these numbers would be appreciated
Thanks: 1 times Was thanked: 629 time(s) in 592 post(s)
The 28 numbers on the 4BBL will probably be HT-HG and HQ respectively, and the 280 2BBL HT-HG. The 992 manifold will probably be LH-HJ and early LX. The 993 manifolds will be HX and later LX.
Photos will help immensely. |
Joined: 16/04/2014(UTC) Posts: 768  Location: Victoria Thanks: 1 times Was thanked: 49 time(s) in 47 post(s)
2812094 is HQ 308 9929853 is LH/early LX 308 2805483 is HQ 253.
Can't help with the others.
Photos will solve it immediately. Geoff, 9929853 is also HJ (most will be from HJ as there are far more 308's in HJ than in LH-LX). The difference between this one and a HQ example is a tapped hole for (from memory) the return spring for the cable throttle. |
Originally Posted by: HK1837  Photos will solve it immediately. Geoff, 9929853 is also HJ (most will be from HJ as there are far more 308's in HJ than in LH-LX). The difference between this one and a HQ example is a tapped hole for (from memory) the return spring for the cable throttle. HJ? That's all a bit too modern for me Byron. Even LH/LX was a stretch.
