Warwick Yellow Offline
#1 Posted : Monday, 24 October 2016 11:36:55 AM(UTC)
Warwick Yellow
I have a HK GTS 327 thats look like it came from a Starsky and Hutch episode.
Have checked the spring height (bump rubber to body) according to the Holden manual and its around 1 inch to much.
They are 4 leaf springs, right thickness but just have way too much " curve"
So need to have springs reset or buy replacements.
Would rather have them reset but need it done right.
Can anybody recommend where I try - I am in Melbourne.
gm5735 Offline
#2 Posted : Monday, 24 October 2016 9:38:07 PM(UTC)
gm5735
Moorabbin spring works should be able to help.
If you have them out and post the spring arch I can give you some comparison numbers. The Shop Manual numbers are given at kerb weight.
#3 Posted : Tuesday, 25 October 2016 8:07:44 AM(UTC)
Warwick Yellow
Thanks gm.
Dont have the springs out yet but will take up your offer of comparison when I get them out in next few days.
#4 Posted : Tuesday, 25 October 2016 8:25:15 AM(UTC)
I have two sets at home and another pair out of a HK GTS (same spring) stored elsewhere that I can measure as well to compare.
This page was generated in 0.022 seconds.
