Hk186p Offline
#1 Posted : Sunday, 20 November 2016 9:06:13 PM(UTC)
Hk186p
Hk Ht Hg Owners do any off you guys know where the fuel over flow pipe ends up this is the one on the fuel filler tube passenger side which exits the floor I took mine off ages ago and cant work out what to do with it it finishes about half way along the vehicle underneath any help or photos would be great.
Tour Director Offline
#2 Posted : Monday, 21 November 2016 6:42:19 AM(UTC)
Tour Director
What model,engine & fuel tank do you have?
Hk186p Offline
#3 Posted : Monday, 21 November 2016 8:45:31 PM(UTC)
Hk186p
Standard tank 16.5 gallons with a 186 engine Hk Premier 69 model car
Ausjacko Offline
#4 Posted : Monday, 21 November 2016 9:56:57 PM(UTC)
Ausjacko
one goes back into the tank adjacent to the filler neck and the other exists out through the floor on the passengers side between the corner of the tank and the rear seat frame. Mine has a piece of black hose joining the two steel lengths.
Hope this shows it better than I explained it
Edited by user Monday, 21 November 2016 10:07:32 PM(UTC)  | Reason: added image
gm5735 Offline
#5 Posted : Monday, 21 November 2016 9:59:00 PM(UTC)
gm5735
It joins the vent pipe from the filler neck with a short length of rubber tube alongside the tank, inside the boot about 150mm behind the hole in the floor. It passes through a rubber angle grommet in the floor, and from there under the car along the front of the tank. It ends up about the middle of the car, and is secured with a metal P clip at the front centre fuel tank fixing screw.
WAHK80737 Offline
#6 Posted : Tuesday, 22 November 2016 9:49:40 PM(UTC)
WAHK80737
Fuel vent line - under car
Looks something like this? Mine is HK GTS 186S Monaro, standard tank. Pic is under car view of the front of the fuel tank.
View inside boot
View from inside boot showing route of vent line and angled rubber grommet at front left of tank
Top of filler neck detail
View of top of filler neck inside boot
Edited by user Tuesday, 22 November 2016 10:00:47 PM(UTC)  | Reason: Added photos
gm5735 Offline
#7 Posted : Wednesday, 23 November 2016 10:11:01 AM(UTC)
gm5735
That's the one, WAHK. Wish I'd had those pictures, which would have saved a lot of typing.
The HK 25 gallon tank is a different arrangement under the car as there is no centre tank fixing screw, but there is a tag spot welded to the tank. The pipe is the same for 16.5 and 25 gallon tanks, but bent differently.
Ausjacko, the HT and HG venting arrangement is different to HK, both for the filler and for the tank vent.
Hk186p Offline
#8 Posted : Wednesday, 23 November 2016 7:33:24 PM(UTC)
Hk186p
Thanks guys but what goes on the end off the pipe on the pipe that exits the floor I do remember it having a clip now but surely its not just an open Pipe?
Hk186p Offline
#9 Posted : Wednesday, 23 November 2016 7:34:53 PM(UTC)
Hk186p
I meant also to say I cant see any photos?.
WAHK80737 Offline
#10 Posted : Wednesday, 23 November 2016 8:00:53 PM(UTC)
WAHK80737
It's just an open pipe
Hk186p Offline
#11 Posted : Wednesday, 23 November 2016 8:10:40 PM(UTC)
Hk186p
Wow that's just ridiculous an open pipe to get crap in that's all I need you, would think holden would off put something there thanks for responding.
8D11PCH2 Offline
#12 Posted : Wednesday, 23 November 2016 9:48:16 PM(UTC)
8D11PCH2
Hundreds of thousands of General Motors-Holden's vehicles have successfully used this method of venting fuel tanks without issue.
Edited by user Wednesday, 23 November 2016 9:55:42 PM(UTC)  | Reason: Not specified
#13 Posted : Friday, 25 November 2016 7:48:04 AM(UTC)
Tour Director
Both Ford & Holden vented to the atmosphere in the past.Once carbon canisters, pollution control and environmental issues took over it all changed.The car companies have to test to ensure NO fumes are detected today.
