69 rust bucket Offline
#1 Posted : Sunday, 27 November 2016 6:01:33 PM(UTC)
69 rust bucket
hello everyone can someone tell me what leads they are using model/type on there hk 307 /327 .i have the stock type looking distributor with the electronic internals.so i'm looking for a set of leads that look standard that run on all the original leads holders under the manifold routing in black as original with the 90deg spark plug boots and standard straight distributor boots max 8mm.i have a set of date coded reproduction leads on the car at the moment but a couple have already failed so I'm not impressed or interested in purchasing the same issue.any help would be good cheers
why drink & drive when you can drift & slide
This page was generated in 0.016 seconds.
