Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
I have a 'rat trap'type clutch in my HG ute with the standard 6 cyl 3 speed manual. I will be changing this to Chev/ saginaw 4 speed set up with a hydraulic clutch using a Dellow clutch master and slave cylinder & fittings.
Should I source a HK hydraulic clutch pedal box or are there off the shelf parts available to modify the HG 'rat trap'pedal box?
Thanks: 1 times Was thanked: 615 time(s) in 582 post(s)
You could use a HG GTS350 manual pedal setup, which you should be able to achieve using HK bits. I can't remember the exact details, but a quick look at HK and HG parts catalogues should sort you out. |
HK clutch master set-up from a std 3-sp crash box is the same. They used the same pedal on all HK/T/Gs with a hydraulic clutch. You may get away with simply drilling the extra hole in the all-synchro pedal.
From memory there should be dimples in the correct spot for drilling the holes to mount the master cyl.
Which side is the slave cyl on? |
The slave cylinder will be on the passenger side for the 11" clutch, same set up sa the HG GTS 350. Thanks guys will source the HK pedal box. Edited by user Wednesday, 6 July 2016 9:16:43 PM(UTC)
| Reason: Not specified
Tony, I think that you have missed the whole point of my post.
I believe that you can keep your pedal box & you just need to drill a hole in the pedal arm.
Cut the necessary holes in the firewall & you're done.
Dr Terry |
Terry
Got it, so drill the hole in the pedal arm and fit a HK 'Pedal push rod' to connect the clutch master cylinder.
Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
Resurrecting an older thread here. Is there a spring pulling the clutch pedal forward (away from the firewall) in the hydraulic set-up AND if so, what does the spring look like (I have two) and where does it attach? There is a small pin hole in the pedal but I can't recall where the other end of the spring attaches- just like I can't recall which spring to use. Cheers Jacko
Joined: 16/04/2014(UTC) Posts: 768  Location: Victoria Thanks: 1 times Was thanked: 49 time(s) in 47 post(s)
