#1 Posted : Monday, 16 January 2017 10:55:29 PM(UTC)
The roof lining in the car is cloth.
It is starting to sag a bit, so I was going to try to glue it.
Got a large needle\syringe from the chemist and was going to try to inject glue through the cloth.
I believe some members have done this.
I was wondering what glue would be most useful, it needs to be able to be injected through a .6mm needle,
thanks
#2 Posted : Tuesday, 17 January 2017 8:03:12 AM(UTC)
I assume you are referring to a 'late' model car like a VN-VZ Commodore or EA-BF Falcon.
If that is the case, I've seen many different 'fixes' attempted, but they all are domed to failure. The problem is that the sponge/glue material between the cloth & the cardboard backing is crumbling & no glue will stick to it until it is removed.
In Sydney the going price for a whole new headlining (fitted) is $180-$200. At that price why muck around.
Edited by user Tuesday, 17 January 2017 1:21:44 PM(UTC)  | Reason: Not specified
castellan Offline
#3 Posted : Tuesday, 17 January 2017 1:09:17 PM(UTC)
castellan
I am with Terry on this, I had our VS done by a professional when headlining started sagging.
