vyturbo Offline
#1 Posted : Friday, 20 June 2008 4:28:12 AM(UTC)
vyturbo
G'day all,
My car has finally been finished and tuned. It made 320rwkw at 17 psi and 717.3 Nm or torque. Pretty happy with the results.
It was done by Silverwater Automotive Services.
A fair few mods:
CP forged pistons
Argo H beam rods
bottom end balanced, blue printed
balance shaft removed
cam
double row timing chain
valve springs etc
heads flowed
block 'o' ringed
YT 1.8 rockers, molly pushrods
bigger throttle body, moved to driver's side
xtreme clutch
kaaz diff
kkr 560 turbo
kkr 50 mm external wastegate
autronic sm4 ecu, 3 maps low medium and high boost, MAFless tune
MACE plenum spacer and insulator
oil cooler
etc, etc ( a few more but can't think of them off the top of my head)
Edited by user Friday, 20 June 2008 4:29:15 AM(UTC)  | Reason: Not specified
vyturbo Offline
#2 Posted : Friday, 20 June 2008 6:55:45 AM(UTC)
vyturbo
How do i add pictures? Im doing this from work so cant access sites such as photobucket etc, banned from most forums as well (not sure why not this one).
Can i add photos to this site and then link them to this post? If so how?
basketcasebear Offline
#3 Posted : Thursday, 3 July 2008 11:00:01 AM(UTC)
basketcasebear
hey vyturbo,
if you upload you pic to photobucket, and or tinypics, when you have done that, you copy the "img tag, in bucket, or tinypic,, then when you are in your post, you paste that "img tag, in the post,, and then the image will appear!
Q,, you have 320rwkw?? how much is the kw at the engine? without the box, diff?? etc?
trying to find out losses for boxs and diffs
bcb
ptpro
some men see things as they are, and ask "why"
I dream of things that never were, and say, "bloody ripper idea mate, lets try it",!!
DOH!!!
vyturbo Offline
#4 Posted : Friday, 4 July 2008 2:15:09 AM(UTC)
vyturbo
hey vcb,
Thanks, but i cant access photobucket, tinypics etc from my work account. Also Ive just built a new home and havent got internet access there yet.
Not sure how many kw at engine. Ive been told there is about a 25% loss through drivetrain. Dont know if thats accurate or not.
The car made 370rwkw at 7000rpm and 1.5 bar (22psi). Wanted to be a bit conservative and get some longevity out of set-up so backed rev limiter back to 6300 and boost back to 17psi. This is when it made 320rwkw.
sandman77 Offline
#5 Posted : Friday, 4 July 2008 2:29:13 AM(UTC)
sandman77
Why dont you use image shack
Rusty
vyturbo Offline
#6 Posted : Thursday, 10 July 2008 12:12:27 AM(UTC)
vyturbo
Well- like i said before... i cant access image shack, photobucket, tinypics etc, etc from my work account.
#7 Posted : Thursday, 10 July 2008 2:04:18 AM(UTC)
email me the pics... and Ill upload them to photobucket on your behalf...
lrobertson at fastlane dot com dot au
Fastlane Administrator
#8 Posted : Tuesday, 29 July 2008 2:20:54 AM(UTC)
yep... emailed you some pics.
vyturbo Offline
#9 Posted : Wednesday, 17 September 2008 11:34:41 PM(UTC)
vyturbo
Just a quick update. Went to drags a few weeks back and had a few runs on slicks. Best time was 11.88 @ 124mph. Very happy with the time and even more happy with the speed. Definitely the potential for a lower time.
It is a fair bit faster than when i had the vortech blower on. Best time was 12.2 @ 118mph.
Also Leith i emailed you some pics ages ago. What happened to them?
boom Offline
#10 Posted : Sunday, 5 October 2008 2:09:37 AM(UTC)
boom
on what boost? sounds like a good time.
In cubes we trust.
vyturbo Offline
#11 Posted : Wednesday, 8 October 2008 12:02:43 AM(UTC)
vyturbo
Thanks i was happy with the time, but even happier with the speed. I have improved the time to 11.53, but surprisingly the speed was slightly slower.
My biggest trouble is the 60 foot times. Fastest so far has only been a 1.9. I just gotta strike a happy medium between taking off too slow or sitting there smoking it up. A bit more driver skill wouldnt go astray either.
High boost setting is 17 psi. This equated to about 19psi before the headwork was done.
Custom Offline
#12 Posted : Wednesday, 8 October 2008 6:16:32 AM(UTC)
Custom
So how long till you stuff up and it gets impounded.
vyturbo Offline
#13 Posted : Thursday, 9 October 2008 8:38:58 PM(UTC)
vyturbo
Hopefully not for a fair while.
boom Offline
#14 Posted : Sunday, 12 October 2008 12:48:57 AM(UTC)
boom
let a bit of pressure out of the slicks. it may grip better and give you a faster 60ft.
In cubes we trust.
vyturbo Offline
#15 Posted : Monday, 13 October 2008 9:38:06 PM(UTC)
vyturbo
Yeah, i was getting more wheel spin than i thought i would and more than i wanted. What pressure would you suggest?
driveshaft22 Offline
#16 Posted : Monday, 25 May 2009 2:01:47 AM(UTC)
driveshaft22
Hey mate, I know this is an old post but I wanna know more about how the KKR560s go. Im about to order one for my 3.8L V6. you can catch me at [email protected] thanks.
Guest (5)
This page was generated in 0.083 seconds.
