KBM Offline
#1 Posted : Monday, 24 April 2017 7:49:00 PM(UTC)
KBM
G'day, I'm new to this forum caper and while looking through previous posts I noticed a need for old quadrajet carbies. I've gone through the back cupboards of the shed and found a couple of old carbies. one I bought back in the late 80's. the numbers are 7042282 with 2631 in the next line. it also has a green canvas tag with red washer. I think I can make out the numbers cl432r with what looks like a stroke and 85. there's also a cutout like the old tram tickets of an x below. hopefully this might be of use to someone doing a resto. I'm confident it's an outside usa carby from 1972 suiting an auto which might suit a hq. someone out there might need it as it doesn't fit my old hk's.
HK1837 Online
#2 Posted : Monday, 24 April 2017 8:24:12 PM(UTC)
I've never heard of that number before. 7042202 and 7041282 yes, both of these can be found on a Holden or Statesman.
7042202 (usually followed by DJ) is off a 4BBL 1972 SBC engine from a US vehicle (I think only L48 at that time), and the 2631 date code is feasible but not on a HQ. This same carby was used on HQ from about 8/73 with 1973 date codes.
7041282 (usually followed by ZF) is off a HQ 308 auto engine, used from the start of HQ through to about 8/73 when it was replaced by 7043284. 2631 would be valid for one of these.
KBM Offline
#3 Posted : Monday, 24 April 2017 8:54:22 PM(UTC)
KBM
got the old monocle out and 7042232 . probably old usa stock sent over here. pity it's as good as new.
HK1837 Online
#4 Posted : Monday, 24 April 2017 9:14:25 PM(UTC)
7042232 is off a 1972 Cadillac 472 or 500.
KBM Offline
#5 Posted : Tuesday, 25 April 2017 10:16:54 AM(UTC)
KBM
Thanks for the info. I dug out another one that's had the auto choke disconnected and would need a kit through it otherwise it's in good nick.
the first digit appears to be a T but I presume it is an upside down 1 so the number is 17056280 with date code 0996.
does the date code go day day month year?
is it off a 1976 holden or statesman?
HK1837 Online
#6 Posted : Tuesday, 25 April 2017 12:16:44 PM(UTC)
17056280 is the 308 carb for all HX Holden and Statesman and all LX 5.0L. It was used up until HZ engine production began. There will also be a handful of HJ's from Pagewood built a few months out from HX volume production with these carbs.
KBM on 25/04/2017(UTC)
LS350 Offline
#7 Posted : Tuesday, 25 April 2017 12:34:59 PM(UTC)
LS350
Our carby number on our 6/71 HqLs 350 is 7029284 ZD 0429
HK1837 Online
#8 Posted : Tuesday, 25 April 2017 2:07:08 PM(UTC)
Some of the early HQ 350 engines got HT-HG carbs, which is what yours has. Same as the earlier HK GTS327 carbs over-ran into the Canadian engine cars, and also HK carbs into HT manual 350's. Pretty normal.
LS350 Offline
#9 Posted : Tuesday, 25 April 2017 3:15:45 PM(UTC)
LS350
Did they use the same jets (71) in the hktg or larger ones?
Edited by user Tuesday, 25 April 2017 3:16:51 PM(UTC)  | Reason: Not specified
HK1837 Online
#10 Posted : Tuesday, 25 April 2017 4:00:25 PM(UTC)
AFAIK they are all basically the same carbs from HK GTS327 through to 8/73 when the clean air engines started and then they started using a US spec carby. The only difference being the different vacuum sources for manual and auto carbs.
LS350 Offline
#11 Posted : Tuesday, 25 April 2017 4:49:17 PM(UTC)
LS350
Thanks for that info HK1837
