77hz Offline
#1 Posted : Thursday, 11 May 2017 3:42:26 PM(UTC)
77hz
HI all
I have a 77HZ premier with a 304 and an aussie m1 4speed behind it. I am wanting to put in a 350/400 box and I need is a list of parts and mods I need to accomplish it.
Current specs:
Engine 304 with a holly 600 so no efi
Gearbox M21 aussie 4 speed with a delow bell housing ( will probably sell this later)
Tailshaft Standard original from the factory
Original specs 253 with Trimatic
Will the original Trimatic T bar shifter be able to be used with the 350/400 and will I need to fit a new speedo cable
Andy
#2 Posted : Thursday, 11 May 2017 4:54:04 PM(UTC)
You'll need to modify the T-bar or get a TH400 one.
New speedo cable and new hole in the firewall for it.
New gearbox crossmember.
New tailshaft and yoke for TH400.
Cable kick down setup for TH350.
Kick down switch for TH400 if not still there.
77hz Offline
#3 Posted : Thursday, 11 May 2017 6:01:32 PM(UTC)
77hz
Thanks HK
Hi
I have been on ebay looking at Cable kick down and kick down switches but there are so many I am afraid that I am a novice at this so any help with part number etc or where to by from (one stop shop) works for me would be greatly appreciated
Thanks and
#4 Posted : Thursday, 11 May 2017 8:48:55 PM(UTC)
I don't know of any such place. If your car was Trimatic before it should already have a kickdown switch and wiring, just need to modify it to get to the TH400 switch. Same for the vacuum attachment point for the vacuum modulator, use the vacuum take-off tree off the old 253 and use it on the 5 litre.
#5 Posted : Friday, 12 May 2017 8:31:24 AM(UTC)
One thing that I noticed in your question was that you have a Dellow bellhousing. That being the case this may be a 6-cyl 4-speed Aussie box. This is what is required when fitting an Aussie 4-sp behind a Chev patterned motor. Having said that it may also have a spacer added enabling a V8 length box to be fitted.
The only reason I mentioned this was that it will effect the tailshaft length. So the tailshaft may not fit to a TH350, where a standard Aussie 4-sp shaft would.
The TH400 is slightly easier to fit. You just use a standard Trimatic kick down switch, re-drill the crossmember & fit the correct tailshaft.
As HK has said to fit either a TH350 or TH400, you will need to modify a Trimatic shifter (far more common) by swapping the lower lever from the right to the left.
#6 Posted : Friday, 12 May 2017 8:58:20 AM(UTC)
Terry, I took it as meaning Andy has a Dellow Chev to Aussie box bellhousing as he states it is a 304 (which I initially thought must be talking about a VK-VL 304 and hence a manual block) but the mention it now has a carby leads me to thinking it is a VN-VSIII engine hence TH pattern block, hence the assumption about the bellhousing.
Andy, Terry is spot on with the mods to the T-bar. Hopefully you still have the wring harness for it - it will plug straight into the HZ harness, just remove the bridging plug in the detent circuit that a manual has, and disconnect/remove the reverse switch harness from the 4spd and plug the T-bar harness in there too. The grey wire will plug into the loom near to the radio somewhere and there is a black with ring lug that you attach to the body.
For the crossmember see if you can find a HQ-HZ sedan/coupe/wagon/Statesman with factory TH400 and grab the crossmember. The same car if it is a coupe or sedan will give you the tailshaft too for the TH400, if yours is a wagon the you want a TH400 tailshaft from a TH400 wagon, Statesman, ute or van.
The kickdown switch for trimtic/TH400 is up high on the accelerator pedal - it is a slide looking thing. There would have been a wire running down to the back of the trimatic from the engine bay for it, on a HZ should have also been another one for the pollution switch.
If you go for a TH350 you need a late HZ or early WB 308 gearbox crossmember from a wagon, sedan or Statesman, plus the kickdown cable and kickdown bracket attachment off the engine. You can buy generic ones and adapt it to a Quadrajet pretty easily.
Both TH350 and TH400 need the engine vacuum pipe connection, do as I stated in an earlier post.
The other problem you might face is either box may foul your exhaust.
Speedo cable, look for a HQ-WB with TH400 or TH350 (for WB has to be one without cruise control) and see where the speedo cable exists the firewall (towards the centre). On your car there will be a dimple there to show you where to drill. Remove the engine and use a (from memory - check first) 32mm holesaw to make the hole. Use a blank speedo grommet in the original hole. Factory cars also have a support clip off the closest heater box bolt, and also another screw through the passenger floor with another support clip. Look at a HJ-HZ parts catalogue and you'll see what I mean.
#7 Posted : Friday, 12 May 2017 10:51:15 AM(UTC)
Andy must have an VN-VS 304 EFI block, not a VK/VL 304 Carby block, because he needed a Dellow bellhousing to fit the Aussie box. If he had a VK/VL Carby block, he could've used the factory bell housing, which is much cheaper.
To my knowledge, the Dellow housing is based on the Chev set-up using the shorter (6-cyl) type box. If you have a V8 Aussie box you need a 1.25" spacer, which he makes for this purpose. This takes up the difference in length between the 6 & V8 boxes.
If this is indeed the set-up he has, then his tailshaft etc. will be out by 1.25"
#8 Posted : Friday, 12 May 2017 11:08:38 AM(UTC)
I have seen both Dellow and CRS Chev to V8 4spd housings. The CRS ones were multifit at one stage for both Chev or Holden pattern.
