8 Pages«<34567>»
KBM Offline
#81 Posted : Monday, 31 July 2017 5:57:02 PM(UTC)
KBM
did commodore come with a red v8? when did they change to blue?
SLENUT Offline
#82 Posted : Monday, 31 July 2017 6:25:51 PM(UTC)
SLENUT
VB's had red colour motors.
VC was the first blue, XT5.
The Commodore SL/E fanatic.
#83 Posted : Monday, 31 July 2017 7:26:04 PM(UTC)
Some of the XT5 components came earlier than VC/WB, but as SLENUT says the actual blue painted engines arrived with VC and WB in 1980.
castellan Offline
#84 Posted : Tuesday, 1 August 2017 8:15:12 AM(UTC)
castellan
Originally Posted by: castellan Go to Quoted Post
You could have bought an LH L34, and it was a regular production vehicle. There were probably more of them made than HQ Sandman. GMH simply asked dealers to be careful who bought them, and there were plenty available as used cars by 1976 which anyone could buy.
Who were they going to sell them too ? who wants a car without a arm rest.
They were only for people who wanted them for the race track work.
Be careful means, do not sell them but only to people in the know.
Ford had the XA RPO and only people in the know could get the good bits, the average dude had no idea at all and could not get one, just as it was with the L34.
Fact is that your average Joe Blow could not walk up and get the cars new from the dealer and that makes it not a public production car.
One of the cars that were a better than average car was the VU SS ute 50th anniversary if you were lucky you got the better performing engine than the others.
Anyone who bought a bench seat Holden Belmont in 1974 didn't get armrests or console shift either!
The L34 was built to homologate the LH Torana with good bits for Group C racing, there is no secrecy in that. It was the Evolution of type of the LH SL/R, of which from memory GMH had to build half. Exactly the same as the 4 x Group A Commodores were the evolution of type of the base vehicles. GMH didn't need to advertise the L34, it was intended for race teams (unlike the A9X). However anyone could buy one if they knew about it and tried hard enough. In fact you could argue it had to be a regular available vehicle to homologate it for Group C. The L34 was GMH's first Group C homologation too.
Yes and all but the fact is that anyone could buy a A9X without question and it was a full car. not a hack without a centre console, like who wants to drive a car like that without a centre console and at that price.
It would be like pulling teeth for Joe Blow to get one and you would get no discount.
One would be better off just getting a SL/R 5000 and doing the engine up yourself as many did, when I got mine it had extractors and a 650 Holley and a 3.08 LSD.
If you did get a L34 and raced it you would have to pull the engine down anyway toss in the cam and get the engine balanced at least. with a go for it SL/R 5000 you could do the same and order L34 pistons and rods valves and rockers etc etc. the biggest problem was the stupid little crappy banjo diff, I know of people who always carried a spare banjo around and could tell you just how fast they could change one on the side of the road.
castellan Offline
#85 Posted : Tuesday, 1 August 2017 8:37:38 AM(UTC)
castellan
I have seen a red HZ block with 3.3 cast on it and the head was a red head but on the exhaust and intake side, just above that it's casting was like the blue head sloping down to the 9 ports, not flat like and then bending down to the ports like all the other red 6 were. it's where the part numbers are cast and the H or L are cast that I am on about and this thing had exhaust the blue motor exhaust valve rotators and it was all original rocker cover never been removed. and I have seen one the same in a hot rod 3.3 cast block and ZL prefix with same casting type head.
They must of cast the heads in the last months of the red, if you want I will get the casting dates next time I see the dude who owns it, I think I have the dates of the first one I seen as well somewhere.
#86 Posted : Tuesday, 1 August 2017 8:48:48 AM(UTC)
An A9X wasn't a factory race car, no different to buying an SLR5000 or SS with 5.0L, it was simply the final evolution of the LSR5000 and SS with 5.0L, very much like the final 150 XU1's. L34 was extremely limited build which was why it was hard to buy. In the end there was around 1200 GTS327's, 700 odd HT GTS350, 450 HG GTS350, about 650 HQ GTS350, many thousand XU1's but only about 250 L34 available to the public. This was why it was hard to buy, and dealers were advised to sell to people with Cams licences as the intended use of the car was to race. If you had the $ and knew a dealer well enough you could buy one though. It wasn't aimed at comfort, it was built for racing and a console would be a waste of money for the buyer. GMH never intended for it to be an everyday driver, they wanted you to do what you say and buy a GTS or an SL/R. I actually owned a whole L34 upgrade kit for an SLR5000 (suspension and brakes, not the engine). It was every part needed to convert to L34 spec suspension and brakes, all new in boxes or with part number tags attached. I sold it many years ago to an avid L34 collector.
Yes the banjo was a weak point, but the L34 was one of GMH's most successful Series Production and Group C race cars. It won at Bathurst twice, came within a wrong Cams decision of winning a third time. Also won many other races. In that era no other GMH product did that using a road car. The later stuff that won multiple times were not road cars, they were factory prepped race shells like the LX's and VH's.
castellan Offline
#87 Posted : Tuesday, 1 August 2017 8:48:56 AM(UTC)
castellan
9/12/1979 cast block it was with the 3.3L casting and the head, I have the head date casting somewhere and I think it was before the block date by a bit. but to look for the info I have written down I will be lucky to find it.
#88 Posted : Tuesday, 1 August 2017 9:10:06 AM(UTC)
It may just have been the top part of the head pattern changing ready for blue. GMH did this a bit, they entered changes into production early that had no impact, like the XT5 V8 longer head bolt bosses introduced mid 1978. Also blue intake manifolds and HEI dizzys first introduced in Bedford. I'm sure there were bits on the red engines as well. They would have stopped red engine production at a certain date and then changed to blue engines after changing whatever had to be changed in the plant. Most likely once the schedule was finalised and they knew exactly how many were required. They'd probably build a stock of warranty engines in this timeframe too. The red engines would be stockpiled for the final HZ's assembled alongside WB and VC in 2/80 and 3/80.
Edited by user Tuesday, 1 August 2017 9:10:45 AM(UTC)  | Reason: Not specified
#89 Posted : Tuesday, 1 August 2017 9:58:53 AM(UTC)
A lot of planning goes into a plant shutdown. They cost a fortune and any small changes leading up to a shutdown to save time would be used. Any planned maintenance would be done at the same time as a production change shutdown. This is no doubt why engine number sequences and chassis numbers never line up 100% all the time.
Did Holden plants run 24hr a day?
#90 Posted : Tuesday, 1 August 2017 11:10:48 AM(UTC)
100%. I have been designing conveyor control systems upgrades for the last 10 years on and off. We try to design to minimise outage times wherever possible, try to install as much new infrastructure in parallel with existing equipment wherever it is sensible, possible and financially viable to do so. We normally take advantage of 1 day outage periods in months leading up to the main outage to install either equipment, make changes or install scaffolding, hoarding or whatever is needed to then continue to install safely with the plant running. GMH would be no different, if a running change could be made and just as importantly proven to work prior to a major change then it makes sense for them to have done that.
Engine and chassis numbers simply cannot align. It would be physically impossible. Every GMH engine got an engine number, even replacement engines after a certain date. ALL of those engines were produced in the one location, and they were given the numbers at that location. Then they were shipped off in crates of six or 4 or whatever other number they fitted into the transport crate. Some went into CKD packs (these had a body pack and a mechanical pack, and in that mechanical pack would be an engine). Those engines went to dozens of assembly locations at different times such as: Pagewood, Elizabeth, Acacia Ridge, Dandenong, Woodville, Mosman Park, Trentham, Brisbane Valley plant, South Africa, Phillipines, Trinidad & Tobago, Malaysia or wherever else they were assembled. Some of these locations never even had a chassis number, but most of the cars did but they used their own sequence numbers that meant something. The prefix letter gave the ADR revision, the second two have the series, the last letter gave the assembly location. Engine numbers have none of this info, and in many cases don't even give you the series. Some of the ADR revisions in the chassis numbers are not related to the engine. So to make the engine number align with the chassis number there would have to be dozens and dozens of different engine numbers and sequences, and those engines would then be very specific to a particular vehicle in many cases rather than be a generic engine that could be utilised as a stock item at the assembly plants and be used as required. To achieve this would cost money in terms of delays - damage an engine, have it blow up, have a car delayed on the line which means the engine has to be stored or any such circumstance. GMH were about shaving costs, having common items to reduce cost and reduce overall inventory especially at the time critical assembly plants. This will be the driver behind using QL, QD, ZL etc engines in auto LH and LX Torana as they were physically identical to Holden engines (manuals had a smaller clutch hence they had their own engines).
I believe some GMH plants ran 24hr. The one I think must have is the press plant at Woodville. Just think about every single pressing required for every GMH vehicle - this was the only press doing it. Think about the inner door frames, all the pressed small bits and pieces used to weld together to make a car. Add all the pressed heavier steel used for crossmembers, chassis rails on HQ-WB, door hinge pressings etc. Add also that GMH pressed panels for Nissan and probably others. I cannot see that press stopping. I imagine the casting foundries that did engine blocks, transmission housings, brake rotors etc probably ran 24hr too. There are others too that would have been making parts for all plants, like the Woodville transmission plant, the rear axle assembly plant and other like it. Also the external suppliers that made all the componentry for the cars, like whomever did all the aluminium castings, the wiring harnesses, the glass, the plastics, the nuts and bolts. All of this was effectively sole sourced. Whomever was doing logistics must have been a 24/7 operation too.
Edited by user Tuesday, 1 August 2017 11:11:59 AM(UTC)  | Reason: Not specified
#91 Posted : Tuesday, 1 August 2017 1:33:05 PM(UTC)
Yeah I see how the engines are only approximately right with a date code. Ford used the same number for chassis/body as the engine correct? They must have stamped them when they were in the vehicle?
I imagine a foundry would be very inefficient if it was shut down everyday?
On a side note, I worked at Cadia for a while. They had (at the time) the biggest ball mill in Australia. It was planned months in advance for a shut. Apparently it drew a massive amount of power out the grid on start up. I then moved to another tiny magnetite mine. Tiny ball mill, they used to only run it at night to save money by using off peak power...so we did a start up every day. You would have loved it HK. The mill motor looked like it came out of 1940. It had an antiquated clockwork thing that tripped each phase as it got up to speed.
#92 Posted : Tuesday, 1 August 2017 1:44:55 PM(UTC)
Ford did, but they only had one assembly plant IIRC.
I worked at the EMD plant in Newcastle that had a ball mill, it also had planned shuts up to a year out.
1940 is relatively modern. At Newcastle Steelworks we had stuff not only from 1915-16 but some of the buildings and cranes were old when BHP relocated them to the site. The "clockwork" thing will be probably just a set of resistance banks on a slip ring AC motor rotor circuit. These are still in use commonly today (different control though) but rarely installed new as AC VS drives are so cheap and slip ring motors need maintenance whereas squirrel cage hardly need any.
castellan Offline
#93 Posted : Wednesday, 2 August 2017 8:32:56 AM(UTC)
castellan
Have you seen the 6 cyl red head casting that I am on about, they must of been a experiment with the top half casting for the blue and why not give it a go, maybe the water jackets are designed a bit better or to save weight. even the head castings do change as the years go by that one can not see, the V8 heads changed in the HQ with thicker combustion floor casting.
Ford has castings with revisions marked on them.
I wonder if them last red heads got the blue type water passage holes at the deck face and block ?
I still recon that the V8 block had the longer valley bolt castings change in the HJ as I pulled a mates 308 HJ ute down in 1985 and it had them, also I found that the valley casting where the cam is just sitting under did not dip down like the early ones do.
#94 Posted : Wednesday, 2 August 2017 9:07:15 AM(UTC)
Haven't seen the red heads in question. Probably experiment as stated. Will probably have an X or other mark on them, like the X's on F5000 blocks and trial ADR27A V8 heads.
Definitely not HJ introduction, otherwise the torque specs for those inner head bolts would have changed and the parts catalogues would change to remove the shorter head bolts. I have the GMH service letter for it, dated mid 1978, that talks about only 2 x head bolt types now needed rather than 3, and torqued identically and even gives the breakpoint engine numbers. Breakpoint numbers are below and all are mid 1978. This is essentially the start of V8 VB engines and is probably the same breakpoint for the 308 changing from 9.7:1 to 9.4:1.
QT985300
VR1047
NT11795.
JBM Offline
#95 Posted : Wednesday, 2 August 2017 9:40:43 PM(UTC)
JBM
Originally Posted by: SLENUT Go to Quoted Post
Another few, mainly Commodores.
V7X 304 V8 are Brock spec. Only 1000 made too... Also some people say LV2 denotes Brock spec
There is no 304 V8's in VK and VL models, these are 308. Only 304 are fuel injected.
Lastly, all diffs in UC Torana/sunbirds, VB- half way in the VK range, doesn't matter what motor they have are 10 bolt Salisbury diffs cause 10 bolts on the cover plate. THat one still causes many pub arguments.
I call it an 8 bolt Salisbury or the evolved from Banjo diff, whether it's better than a Banjo I don't think so, especially easy to repair to get you going in no time, but at least they all had a fine spline axle.
Maybe it cut down on weight by evolving into a Salisbury ?
Small Salisbury is a Bango in disguise. The main reason banjo diffs failed under high-stress loads was due to housing flex. The Salisbury style diff housing eliminated some of this.
Another myth:
GMP&A Race shells built into race cars are A9Xs.
James
#96 Posted : Thursday, 3 August 2017 7:22:02 AM(UTC)
^^Conversely, the myth that an A9X ever won at Bathurst. A Torana did.
#97 Posted : Thursday, 3 August 2017 8:35:38 AM(UTC)
Somehow I think racecars could be given a bit of slack.
I would venture to say that the majority of the winners from the 1960 Armstrong 500 to the 2018 Bathurst 1000 were not 'real' cars.
OK, every car since the V8 series in 1992 began as a purpose-built race shell, but what about the earlier cars ?
The R32 GTRs probably began life as real cars & maybe some of the Sierras & the Jag, but most of the Group A & Group C Commodores were built from shells just as the A9Xs were.
Was Bob Morris's 1976 L34 built from a shell or was it a real car with a compliance plate. I'm pretty sure Brock's 1975 L34 had a compliance plate.
Moffats 1977 Falcons (the 1-2 win) weren't even XC Falcons. What about Moffats 1970 & 1971 winners, were they 'real' GT-HOs or were they tarted up GTs just like the Mahoneys Rd 'Phase 4s'.
Also the GT500 Cortinas were "fiddled with" seriously, post-factory, which wasn't in the spirit of 'Series Production', was it ?
Myths surrounding racecars could make for a longer thread than this one.
#98 Posted : Thursday, 3 August 2017 8:55:07 AM(UTC)
Terry, not coming from the BS Journalists that throw up from time to time when they name the LX A9X as the "#1 Aussie Muscle Car" or similar, with the reason being "it won Bathurst by 6 laps in 1979" or other such nonsense. The LX Torana onwards cars were very much race cars built by GMH and thus the road going cars really have no racing claims, although the componentry they homologated gives some links. Before that I'd hazard a guess most were "real" in terms of they were built as a road going car. Sure many were not what they seemed once Group C got into swing.
I'd hazard a guess that the following were real cars. I know for a fact some of them were:
Bruce McPhee's 1968 HK that got shown the flag, as was the car that crossed the line first (Des West). Plus all the other GTS327's.
Bruce's 1969 Falcon and a lot of the HT's. The HDT HT's were real cars but not with production engines, but were still GTS350's.
Don Holland's 1970 XU1.
Most of the 1971 XU1's and probably the Privateer XU1's in 1972. The 1972 HDT XU1's were like the LX race cars, they were factory prepped race shells, although supposedly one of them (Brock's) was crashed prior and they had to re-use an older car for Bathurst, although it as probably a proper XU1.
I never saw under the bonnet of Morris's car, it was on the hoist at the Bathurst Museum when I was there so didn't see under the bonnet.
Not sure what Ford were up to in those early days, but with Harry in charge you'd never be surprised.
#99 Posted : Thursday, 3 August 2017 9:25:48 AM(UTC)
When you look at some of the accidents those cars had, then they were back racing later on, they had to have been different shells with all the racing bits put back in them?
I think most know that the two door Toranas raced by big teams were GMPA bodies. The A9X were only for homologation. The GMPA tagged bodies are really a spare parts body with those tags aren't they? General Motors Parts and Accessories?
However you could have bought an A9X and raced it and as far as I know a fair few were. You read about them being raced, then being put back to road cars, registered and sold. I don't think you can register a GMPA tagged body can you?
Edited by user Thursday, 3 August 2017 9:27:19 AM(UTC)  | Reason: Not specified
#100 Posted : Thursday, 3 August 2017 9:53:31 AM(UTC)
The GMP&A LX's were almost all complete cars when they left the assembly plant, they just weren't complianced, although they did have a chassis number. Afaik they had no emissions equipment fitted. They had regular 308 and M21 in them. The HDT cars were a bit different where they supplied some bits themselves (driveline, seats and seatbelt plus more from memory). What they effectively were was an assembly plant built race car but without the race mechanicals, but not an A9X, just built to A9X specs as far as rear axle and crossmember at concerned, plus with A9X body kit.
Yes some privateers raced A9X road cars, but the bulk of the low budget privateer cars would have been L34's with A9X homologation updates. Some of them may have even been 6cyl or 4cyl bodies, like Garry Willmington's Group C XD.
Yes you can register any body with a GMH applied chassis number, don't need ID plates. You wouldn't want a race shell as a road car though as they weren't body deadened and weather sealed to save weight. They'd leak like a sieve in inclement weather.
Terry, I read that Moffat's 1977 car was an XB built from a body in white after his transporter and XA coupe burnt to the ground, but Bond's 1977 car was built from a an XC GS.
Edited by user Thursday, 3 August 2017 10:04:24 AM(UTC)  | Reason: Not specified
Guest (32)
8 Pages«<34567>»
This page was generated in 0.113 seconds.
