#1 Posted : Friday, 20 April 2018 1:00:15 AM(UTC)
Can someone tell me what car the RIGHT air cleaner suits?
RIGHT - Passenger side facing snorkle, breather at the rear of passenger rocker cover.
MIDDLE - All 308 HQ-HJ ADR27 engines regardless of A/C or not.
LEFT - LH,LX with air conditioning only.
Photo of the lid if that helps
Edited by user Friday, 20 April 2018 1:05:30 AM(UTC)  | Reason: Not specified
#2 Posted : Friday, 20 April 2018 6:52:09 AM(UTC)
Will check later when I have more time, but the RH one I think is LX Torana ADR27A without A/C. Does it have the small choke fresh air supply pipe underneath like the other two? It shouldn't have this as later LX got its choke hot air from the inlet manifold.
The other possibility is VB Commodore however I think these were the same as a HZ.
#3 Posted : Friday, 20 April 2018 9:13:02 AM(UTC)
It only has the usual two small hose fittings on the underside, heat valve/switch or whatever it is.
Edited by user Friday, 20 April 2018 9:16:26 AM(UTC)  | Reason: Not specified
#4 Posted : Friday, 20 April 2018 9:35:00 AM(UTC)
Almost certain it is ADR27A Torana without air. These have the oil filler passenger side front so the PCV air supply is passenger side rear. The A/C Torana V8 has the oil filler on the driver’s side front like a Holden or Statesman and the A/C box gets in the road of the PCV air supply so it moves to the passenger side front on these.
Edited by user Friday, 20 April 2018 9:44:45 AM(UTC)  | Reason: Not specified
RigPig on 20/04/2018(UTC)
#5 Posted : Friday, 20 April 2018 10:14:45 PM(UTC)
Cheers for that info Applause
Thats a lot of different air cleaner assemblies in just a handfull of years.
Thanks again
Wayne
#6 Posted : Saturday, 21 April 2018 9:27:07 AM(UTC)
There is heaps when you start looking, same with rocker covers.
