#1 Posted : Friday, 17 December 2004 4:29:09 AM(UTC)
Looking to recon the original 149 HC Red Block in my EH to take normal Unleaded. It has been suggested that I should bore it out to a 186. However this would increase the power of the engine and require the whole drive chain to be upgraded... no thanks. Instead I am looking for the 149 LC pistons. It will drop the power of the engine, but it will mean the recon will cost less - which means I can put the money saved towards respraying the old girl. A worthwhile sacrifice. Anyone know where I might find some?
#2 Posted : Friday, 17 December 2004 7:56:12 AM(UTC)
Is'nt the drive train the same for a 149 EH and a 186 HK ? Same banjo diff, same gbox (crash first) etc. The EH 179M had hardened gears,but that up grade was carried out on the rest of the manuals after that.
Webby
#3 Posted : Friday, 17 December 2004 4:50:56 PM(UTC)
Hi madness.
Firstly, why do you want to drop the compression of a 149. A 149 HC has a comp ratio of only 8.8 which is fine for normal unleaded. The lo comp 149 was created for the old Standard grade fuel which in the early sixties had a RON of aroun
#4 Posted : Friday, 17 December 2004 8:06:01 PM(UTC)
Unfortunately my EH is January model, so it is the older drive train.
Interesting point about the 179 head though.
Thanks Webby and Dr Terry.
