#1 Posted : Wednesday, 29 December 2004 6:14:11 AM(UTC)
I have recently purchased new window seal rubbers for me LE. These rubbers are of a different construction to the originals, but same profile. As the glass pushes on these rubbers when closed to make a seal their resistance will not allow the glass to shut properly, thereby not sealing.I have proved it as I replaced the new one with the old shitty one and it sealed perfectly. It has too many tears to be of use. Is there a product on the market which can soften the new glass seals or any suggestions. I have purchased 2 rubbers from rare spares at $50 a pop. They are much firmer than the originals....Thanks
#2 Posted : Wednesday, 29 December 2004 8:38:28 PM(UTC)
Sometimes when you replace new rubbers you may find they are harder than what you have in place now, however over time they will soften.Rare Spares product RM5 is a non-silicone softener. It should be sprayed on to the rubber and ideally the doors closed
#3 Posted : Sunday, 2 January 2005 11:07:59 AM(UTC)
rubber care by wurth
