Rangie Offline
#1 Posted : Saturday, 17 July 2021 1:26:25 PM(UTC)
Rangie
1st time post here, so thanks for any reply's ..
The problem I have with my 308 is I have coolant coming out the driver side
header flange, not ideal. The car is running fine & not getting hot or missing.
So how does the coolant get there ?? I'm thinking maybe head gasket, I have'nt
given it a compresson test yet. Thought I'd just see what you guys think would cause
it to happen..
cheers Jeff
#2 Posted : Saturday, 17 July 2021 1:29:57 PM(UTC)
Do you mean out the exhaust oft between the block and the head?
Rangie Offline
#3 Posted : Saturday, 17 July 2021 6:18:05 PM(UTC)
Rangie
it's coming out the exhaust, if it can get in the header from there
then it could be the issue.
#4 Posted : Saturday, 17 July 2021 7:45:26 PM(UTC)
If its coming out of the port into the header than the port wall in the head is stuffed. New head needed
Rangie Offline
#5 Posted : Sunday, 18 July 2021 11:41:33 AM(UTC)
Rangie
Well it will be a week or 2 before I will have time to take it apart &
check it out.. I'll let you know what I find ..
Oily Offline
#6 Posted : Tuesday, 20 July 2021 4:50:24 AM(UTC)
Oily
Hi
Is it possible that it’s coming past the thread on a manifold bolt.
Normally the holes are blind but it’s easy to punch through if drilling out a broken bolt. Cheers
Guest (6)
