3 Pages<123>
Oily Offline
#21 Posted : Wednesday, 27 October 2021 6:15:08 AM(UTC)
Oily
Ron
Hi Aussie 4 speed has the same external dimensions as 3 speed all synchro and trimatic it is the gearshifter that is the problem as the strengthening crossmember in the floor is in that very location.
We all have owned or seen cars with this cut out but legally it’s frowned upon.
A possible alternative would be to set your floor shifter up in the Saginaw location bolted to the floor like as in an early Opel 1900 Torana 4 , though from memory the action is clunky .
#22 Posted : Wednesday, 27 October 2021 7:38:45 AM(UTC)
To fit an Aussie 4spd in a HK-HG you have to butcher the main underfloor crossmember that supports the seats. Which at least means a large spend on Engineering to get it right, at worst makes the car un-registerable. I wouldn't bother. Aussie 4spd are not a good box in a commercial. Reverse is the same ratio as 1st. Aussie 3spd is a lot better box for a commercial, as reverse is really low (3.74:1) so you don't burn up clutches reversing up hills, or conversely will allow you to run a highway ratio rear axle like 2.78 or 3.08 and still have a useable reverse gear. I'd stick with the auto column shift. Far, far easier as you have it already.
#23 Posted : Wednesday, 27 October 2021 8:12:40 PM(UTC)
An aussie 4 speed can be fitted to a ht/g if desired. But as said the shifter doesn't fit, clashes with the under floor cross support. Don't butcher that as other people did in the day.
The trick is to make the shifter hole in the original position of a ht/g saginaw or opel shift and mount the Aussie shifter on top of the floor (might have to custom make a flat piece of metal to suit the hole) . Then it's just a case of lengthing the 3 rods by about 4 inches at the same time making sure they are the right shape to fit around the cross bracing.
I then cut a section out of the shifter so that it is probably half the length of a typical hq/j one and it falls beautifully yo hand and shifts are nice
Edited by user Wednesday, 27 October 2021 8:17:22 PM(UTC)  | Reason: Not specified
aKabud Offline
#24 Posted : Wednesday, 27 October 2021 9:43:48 PM(UTC)
aKabud
When fitting the Comaro that has a stud pattern the same as a HQ rather than change the front rotors to HQ why not re-drill the axles that came in the Comaro diff to the same as the early Holden pattern. I seem to remember axles being re - drilled some years ago.
aKabud
Oily Offline
#25 Posted : Thursday, 28 October 2021 7:50:25 AM(UTC)
Oily
Ron
If the 253 traumatic combo has a gear selector on the right side eg was column shift. That’s a good option as you will only need to change the sump and pickup and you would have a column shift paddock runner.
The tail shaft and diff / yoke would need upsizing for rego.
You have Toowoomba swap in a couple of months.
I saw a v8 flanged 2.78 at rocky swap for 80 bucks but it was drum to drum and we were in our polo. Would have been value as it was a long bolt centre.
#26 Posted : Thursday, 28 October 2021 9:16:39 AM(UTC)
aKabud
It’s not just redrilling axles. It is also drums and machining the axle flange down to the right size, then the drums will be loose. Far easier and cheaper to fit HQ rotors and calipers, and the HQ rotors would be a better match to the Camaro drums than HK-HG.
#27 Posted : Thursday, 28 October 2021 9:17:55 AM(UTC)
Originally Posted by: Oily Go to Quoted Post
Ron
All 2.78 and 3.08 are the long bolt housing. There were no 3.36, 3.55 or 3.9 V8 banjo centres, only 2.78 or 3.08. $80 is cheap today though for a HK-HG 2.78 banjo, possibly LSD as well as most HK were
Edited by user Thursday, 28 October 2021 9:20:31 AM(UTC)  | Reason: Not specified
#28 Posted : Thursday, 28 October 2021 6:56:08 PM(UTC)
Was thanked: 41 time(s) in 40 post(s)
Ron
my LH SLR5000 had a 3.36 banjo in it ( I bought it used not new so have no idea of history) with fine spline axles
(as I found out when I pulled the centre to fix a weeping gasket)
These different?
#29 Posted : Thursday, 28 October 2021 7:15:05 PM(UTC)
GMH only ever fitted 2.78 or 3.08 banjo to V8 cars, be it HK-HG or LH-LX. 2.78 was built for HK 5L and 3.08 for HK 253. They were initially nodular carriers when built by Borg Warner whereas the other 6cyl ratios (3.36, 3.55 and 3.9) were GMH grey iron. GMH later used 2.78 and 3.08 in some 6cyl applications like LC and later LH Torana but never used 3.36-3.9 behind V8. They did offer a 3.08 in HK GTS to go behind 186S and M21 Saginaw but it was a V8 diff with a unique tailshaft to suit.
If an LH SLR5000 had a fine spline banjo in it, it at least would have been made using a HZ or possibly an LX centre with a V8 yoke added. All 5.0L LH-LX will be 2.78 LSD banjo with some exceptions like L34 with close ratio M21 or the rare retail order car with a 3.08. Just about all 4.2L LH-LX manual will be 3.08 banjo, from memory auto got 2.78.
Smitty2 on 28/10/2021(UTC)
#30 Posted : Thursday, 28 October 2021 7:54:50 PM(UTC)
Ron
These different?
no way... you with something different??? never... Shame on you no the king here..nah no way...
Edited by user Thursday, 28 October 2021 7:55:52 PM(UTC)  | Reason: Not specified
#31 Posted : Friday, 29 October 2021 6:51:04 AM(UTC)
Wasn't the 3.36 rear axle an homologated option for an L34 ?
#32 Posted : Friday, 29 October 2021 12:23:31 PM(UTC)
indeed.. correct!
had not thought of that, into the library and
checked my copy of the 'LH SLR5000 with L34 option'
CAMS homologation papers and amendment 12/4V lists-
Rear Axle ratio
Optional Equipment
3.36: (37/11)
Dated 1 October 1974
Edited by user Friday, 29 October 2021 12:54:23 PM(UTC)  | Reason: Not specified
#33 Posted : Friday, 29 October 2021 2:44:54 PM(UTC)
It may have been a homologated option as a sneaky way to allow LH to race with an alternative rear axle ratio but GMH would never have built one. Just like 3.9, 3.36 and 3.55 A9X rear axles. Or M21 or close ratio M21 on XU1.
Plus the homologation is not for L34 anyway. You’ll notice they added 3.36 as an optional rear axle twice in 2/2V on 15/5/74 and 12/4V on 1/10/74. Why? Who knows? The homologation is for LH SL/R though not L34 and yes the 3.36 rear axle was optional on LH SL/R as the performance rear axle ratio behind the standard 3300 whether M20 or M40. The whole LH homologation is for LH SL/R and later into LX SL/R with SLR5000 and L34 both treated as variants. The LX is an evolution of type on the LH.
I just had a look at the LH features manual and there are no optional rear axle ratios for any V8:
L31 M21 or M40 - 2.78 LSD
L32 M20 - 3.08
L32 M40 - 2.78
L34 M21 - 2.78. There was a close ratio L34 M21 and it came with a 3.08.
LX is the same, except A9X had the "optional" MC7 but either it or the standard M21 had 2.60:1 standard with no options. Sometime during scheduling the A9X specification changed from G70 to GU4 rear axle and that is why some A9X are 2.6 and some are 3.08, but there was no optional rear axle.
Edited by user Friday, 29 October 2021 3:15:36 PM(UTC)  | Reason: Not specified
8D11PCH2 Offline
#34 Posted : Friday, 29 October 2021 9:09:48 PM(UTC)
8D11PCH2
Variant form 2/2V homologated the optional 3.36:1 rear axle ratio in the SL/R 3300 model and Variant Form 12/4V homologated the optional 3.36:1 ratio in the SL/R 5000 which in turn allowed the use of the 3.36:1 ratio in the SL/R 5000 L34 variant in motorsport competition.
A minimum of 250 units of the base model SL/R 3300 fitted with the optional 3.36:1 ratio diff were all that was required for homologation.
Edit - correction: A further production of 250 units of the SL/R 3300 model after the first 500 units was required to homologate the optional 3.36:1 rear axle ratio however, these 250 cars were not required to be fitted with the optional ratio rear axle.
Edit 2. The first 500 LH SL/R 3300 cars recognised the 2.78:1 and 3.08:1 rear axle ratios.
Edited by user Saturday, 30 October 2021 4:10:14 PM(UTC)  | Reason: Not specified
#35 Posted : Friday, 29 October 2021 9:27:10 PM(UTC)
I have never seen an LH SL/R manual with a GV4 rear axle, although auto versions maybe I’ve seen one? Can’t remember. All Gpack were 3.36 though.
nineteenfortyeight Offline
#36 Posted : Sunday, 31 October 2021 6:16:48 AM(UTC)
nineteenfortyeight
Thanks for all your comments. I can't get over to look at the 253 auto until Monday so I don't know which side of the box the control is. All I know so far is the motor and box are from the same car and it is a good runner. The owner is away for the weekend as Friday was a public holiday in Brisbane. The ekka peoples day was changed to 29th October when the ekka was cancelled due to covid. All the local towns have their 'show day' on different days in QLD. It was a pain in the butt when I was delivering polypipe all over QLD. Mostly milk runs with numerous deliveries along the way and one town would be closed for the day!
Cheers.
Ron
48 215
8D11PCH2 Offline
#37 Posted : Sunday, 31 October 2021 11:22:29 AM(UTC)
8D11PCH2
Pine Rivers had their annual show postponed because of Covid lockdown. Their show day public holiday was also on the 29th October to coincide with their 3 day show rescheduled to the 29th - 31st October.
#38 Posted : Wednesday, 3 November 2021 4:50:34 AM(UTC)
nineteenfortyeight
I checked out the 253 trimatic. The 253 is on an engine stand and has a 4 barrel carby and GMH manifold. It didn't come out of a tonner, probably a commodore. Complete except for starter and exhaust manifolds. The engine number prefix is VR and the trimatic has FD on the id plate. It is also left side control. He thought you may be able to change it over to right side control? The 186 4 speed is still in the one tonner and the cab was still full of parts so I couldn't get a good look at it. Asking $1500 for the 253 trimatic.
Ron
48 215
#39 Posted : Wednesday, 3 November 2021 12:25:20 PM(UTC)
You have to change the sump, pickup and dipstick anyway to fit a 253 into a HG, it doesn't really matter if its from a Commodore which VR prefix is. If it has a 4BBL intake and Quadrajet it may be a blue 4.2 which is all good, just have to watch that to the letter of the law in most States you need all pollution gear but normally wouldn't be applied today. They way to tell if its a blue or red engine is by the intake - if it has a single bolt in the middle on both sides it has red heads. If it has two on both sides it has blue heads. I could also tell you by the digits on the engine number.
If you did get it you'd also need a pair of HQ-WB 253/308 engine mount adapters and exhaust manifolds. Hopefully if it has a Quadrajet it comes with a factory 4BBL air cleaner as these are worth big $ to buy now. Also hopefully it has the HEI dizzy on it still. If you do get it factor in $350 for a Quadrajet rebuild, worth every cent.
I don't have FD as a valid Trimatic code but it may be an obscure one. Most seem to be FR for left shift Commodore 4.2. I any case they can be swapped over but you'd have to get it done properly by a Transmission shop, and you'd have to find an old HQ-WB or LH-LX or similar RH shift 6cyl box to get the internal shift mech as these boxes are natively left side shift and have an internal crossover mech to convert them to RH side shift. In the end it may be cheaper to get teh transmission shop to swap all the good V8 bits over to a 6cyl case. Talk to them first before committing.
#40 Posted : Wednesday, 3 November 2021 4:05:50 PM(UTC)
I have an FD Trimatic as being originally fitted to a late Bedford CF van with a 202.
3 Pages<123>
This page was generated in 0.088 seconds.
