Dodge230 Offline
#1 Posted : Sunday, 24 July 2022 10:22:09 AM(UTC)
Dodge230
Hi team. I need some help. I have brought a reproduction rev-counter for my Monaro off Ebay. Part number is HDMNA-67160 .The seller stated that you must be careful not too wire up incorrectly as damage will result. But then they don't supply a wiring diagram. I have emailed him several times will no reply.
My question is has anyone used one of the gauges and knows the correct way to wire? it.
I am using a output from my Msd 6AL box as the trigger. Back of gauge has 4 wires.
Green is earth
Grey is illumination (dash lights)
Pink ?
Brown ?
Any help would be greatly appreciated
#2 Posted : Sunday, 24 July 2022 1:32:42 PM(UTC)
Pink is 12V Ignition & brown is the ignition trigger which usually goes to the coil negative, but in your case use the MSD trigger.
