#1 Posted : Wednesday, 24 August 2022 7:20:51 PM(UTC)
I had the displeasure of using the standard HQ jack yesterday (in a storm) and found it very inadequate. I had to use all my muscle laying on the ground for leverage to wind the thing up. I can't think this is normal? It is (what I call) the scissor type that is diamond shaped.
I am used to the ht and hj bottle type with the 3 stage screw lift which is easy.
Premier 350 Offline
#2 Posted : Wednesday, 24 August 2022 7:29:04 PM(UTC)
Premier 350
I've still got one, it lives in the Buick. The initial lift is the hard part, it gets easier as the car is raised. Does it need oiling?
#3 Posted : Thursday, 25 August 2022 5:51:43 PM(UTC)
It probably does need an oil, that probably makes a difference, yes, it did get easier as it went up, but still don't reckon those of the fairer... Err.. type would have got it off the ground oiled or not.
