justgm Offline
#1 Posted : Monday, 5 December 2022 8:48:25 AM(UTC)
justgm
Just about to put a new fuel pump in my VN V6 , any recommendations of manufacturer ? Old pump is getting noisy so ,think its time for a new one. Thanks Mark.
#2 Posted : Monday, 5 December 2022 10:25:03 AM(UTC)
There 2 types of fuel systems on VNs.
The early cars had 2 pumps :- 1 in-tank low-pressure pick-up & the external high pressure. If the in-tank fails, the external pump will still pump but will be noisy.
The later VNs just had 1 in-tank high pressure pump, when it fails the car stops.
My guess is that you have an early VN with 2 pumps & the in-tank has failed.
Just replace both pumps. The in-tank was Delphi genuine, while the genuine external was Bosch, I'd stick with the genuine suppliers.
Smitty2 on 6/12/2022(UTC)
justgm Offline
#3 Posted : Tuesday, 6 December 2022 12:10:55 PM(UTC)
justgm
Thanks Doc, yes it is a Series 1 .
#4 Posted : Wednesday, 7 December 2022 6:39:45 AM(UTC)
There isn't really a clearly defined Series 1 VN, there were several upgrades at different times. The only way to find out if yours has the 2 pump or 1 pump system is to check the existence of the external pump.
