#1 Posted : Sunday, 2 January 2005 10:01:36 PM(UTC)
Hi there people!
I cam across an interesting site that shows how you can make an electrical circuit interface between the cars computer and a PC. But since this is the first I have heard of it I just wanted to know if anyone had done this before and what was gained ie can changes be made to the ECU's settings or what?
I have a VS auto 5L
This is all I know:
http://www.techedge.com.au/vehicle/ http://www.techedge.com.au/vehicle/aldl8192/8192hw.htm
Andrew
#2 Posted : Monday, 3 January 2005 1:18:09 AM(UTC)
Hi Andrew.
This device allows your ECU to perform the same as the dealers 'Scan Tool'. It plugs into the ALDL socket under the dash.
In other words, it lets you read the fault codes (& maybe any history fault codes, depending on the softwa
