#1 Posted : Thursday, 18 January 2024 6:29:08 PM(UTC)
Was thanked: 613 time(s) in 580 post(s)
Quick question.
I know the V8 heads inside out.
But what exactly changed when the 173/202 head went from casting numbers 2811929 (H) and 2811930 (L) to 9937262 (H) and whatever the 2850cc head was? These are the HX-HZ, late LX and UC plus VB heads.
I remember vaguely it was just an extra threaded hole for the head temperature sensor maybe? The rest was identical to the HQ-HJ castings?
#2 Posted : Friday, 19 January 2024 6:21:50 AM(UTC)
I think that was about it. The extra lug cast near No.1 & 2 cyls for the extra temp sensor.
#3 Posted : Friday, 19 January 2024 6:57:25 AM(UTC)
Thanks Terry. I was at a place yesterday with a dozen or so red heads, and know someone looking for a 929 head. I'd told him the pollution 2850 head will do exactly the same job but just wanted to confirm.
#4 Posted : Saturday, 20 January 2024 7:47:19 AM(UTC)
I remember one of the old engine reconditioning companies used to supply 'exchange' heads for HX/HZ 6-cyl engines by just welding a nut to the head to take the extra temp sensor.
castellan Offline
#5 Posted : Saturday, 28 September 2024 9:22:41 AM(UTC)
castellan
Quick question.
I think that head is the 2 i have seen with a casting that is Blue head casting like in being having flat faced surface, as when you look at the casting numbers, look along that top edge front to the back on top of the intake and exhause manifold just below the tappet cover, every red head i have seen is always cast curved over like. but this type is just flat, but where the numbers are it's just curved over like normal, but it's more to the frount and rear that differ being flat like, i took a photo of such but the numbers could not be seen. but i know the numbers started with 99 .
I seen it first in a very late HZ 3.3L casting on the block 1 tonne at the wreckers and the next one in a hotrod that a ex car dealer ownes. such sticks out like dogs balls. i did not note the threaded hole tho, but i will look on sunday if it's down at the car show.
