Ohz501 Offline
#1 Posted : Sunday, 8 September 2024 12:39:24 PM(UTC)
Ohz501
Hi, I have an issue with my hz sedan rubbing tyre on passenger side only, tyre on drivers side has plenty of clearance?
#2 Posted : Sunday, 8 September 2024 3:55:24 PM(UTC)
Wheel size and offset? Tyre size?
Ohz501 Offline
#3 Posted : Sunday, 8 September 2024 4:12:40 PM(UTC)
Ohz501
Tyres are 235/60 x 15 on weld 8in rims not sure of offset.
#4 Posted : Sunday, 8 September 2024 8:52:35 PM(UTC)
They will rub if car lowered and/or negative offset. Not sure why on one side not other. Different offset wheels?
#5 Posted : Monday, 9 September 2024 9:44:50 AM(UTC)
If you look at all the trailing arm mounting points, if there was any discretion when the rubbers were put in? Maybe mounted more towards passenger side? You should be able to see by eye where they are (centred or not)?
Ohz501 Offline
#6 Posted : Monday, 9 September 2024 9:59:32 PM(UTC)
Ohz501
I was looking at trailing arms yesterday in the shed, thought I may have a bent one but every looked OK by eye.
Guest (6)
