Fastlane
Holden Forums
Holden Technical Talk
Bosch HEI rebuild/ restoration - parts?
Joined: 2/03/2005(UTC) Posts: 117  ![Australia Australia]()
I have a Bosch HEI that was on my 308 at one stage. I want to refresh it and lock the mechanical & vacuum advance out to use it with a Holley Sniper so I can control timing with the Sniper.
Stripped it down today and there is only 1 metal shim on the bottom of the distributor above the drive gear. My understanding is there should be 2 metal shims sandwiching a fibre shim?
Anyone have any idea where I could source these? Dr Terry maybe, you did a re-curve on a HEI for me probably around 20 years ago now.
Joined: 6/07/2019(UTC) Posts: 452 ![Australia Australia]() Location: bayside Melbourne Thanks: 284 times Was thanked: 39 time(s) in 38 post(s)
Originally Posted by: 308hjute  I have a Bosch HEI that was on my 308 at one stage. I want to refresh it and lock the mechanical & vacuum advance out to use it with a Holley Sniper so I can control timing with the Sniper.
Cheers not in my recollection... so I checked the parts drawings for the V8 HEI and it shows a shim on top of a fibre washer the points distributor has 2 metal shims both sides of a fibre washer HTH |
Thanks: 1 times Was thanked: 610 time(s) in 577 post(s)
I’d just buy a Holley Hyperspark dizzy. I’m using a SBC version of it on my HK. |
Thanks: 7 times Was thanked: 15 time(s) in 13 post(s)
You can probably buy a simple distributor for use with the sniper for what you'll sell a good HEI for.
Fastlane
Holden Forums
