Joined: 15/09/2022(UTC) Posts: 99 ![Australia Australia]() Location: Perth Thanks: 41 times
Hi all Would anyone have a photo or 2 of the correct routing of the steel vacuum line on a V8 Trimatic & also the clips / brackets required to afix same to the transmission. HJ 1 Tonner if that makes a difference Thanks again in advance Edited by user Friday, 8 November 2024 4:42:12 PM(UTC)
| Reason: Not specified
Joined: 21/12/2018(UTC) Posts: 104 ![Australia Australia]() Location: SA Thanks: 29 times Was thanked: 15 time(s) in 15 post(s)
Best I can do. HJ parts book.
 1 user thanked 202tonner for this useful post.
Originally Posted by: 202tonner  Best I can do. HJ parts book.  Anyone got the V8 version of this ? TIA
Thanks: 1 times Was thanked: 626 time(s) in 590 post(s)
Courtesy of Dr Terry. This is HZ but pretty close. The only difference with the HJ book is it gives a close up of the tube attachment under the bellhousing bolt.  Edited by user Monday, 11 November 2024 11:29:06 AM(UTC)
| Reason: Not specified |
Originally Posted by: HK1837  Courtesy of Dr Terry. This is HZ but pretty close. The only difference with the HJ book is it gives a close up of the tube attachment under the bellhousing bolt.  Thanks again
