bslater79 Offline
#1 Posted : Wednesday, 13 November 2024 8:17:52 PM(UTC)
bslater79
Can anyone help ID the month of my CHZ (1979)
I reached out to Holden Heritage but because it's a 1979 build they cannot help. Their records stop in 1978
#2 Posted : Thursday, 14 November 2024 8:05:25 AM(UTC)
you have the car's data plates..?
they have a lot of stuff re the car.. like ADR data but also show the month/year build
#3 Posted : Thursday, 14 November 2024 4:07:28 PM(UTC)
Just ask here. The GMH Service/Maintenance records end mid 1978 when they went to a new warranty system. Around VB Commodore production start.
bslater79 Offline
#4 Posted : Thursday, 14 November 2024 4:41:08 PM(UTC)
bslater79
So there is no records that you can line up chassis or body number with build date - long sorry but ADR plate is missing.
Chassis is CHZ249xx
bslater79 Offline
#5 Posted : Thursday, 14 November 2024 4:46:28 PM(UTC)
bslater79
HK1837- I know you are a wealth of knowledge....the other mystery is the Chassis prefix appears to end in P (Perth) but the body is a Brisbane assembly prefix 4922xx(B)... Holden Heritage suggested the likely explanation is a bad dye stamp on Chassis and should be a B.
Your thoughts?
Mosman Park Assembly finished during HQ and as far as I am aware they only ever assembled cars from Woodville or Elizabeth bodies. Acacia Ridge bodies only ever went as far as Pagewood I believe, and rarely Holdens, mostly Torana pre LJ. So the chassis number has to be Acacia Ridge, nothing else even looks like a B at that stage, only A or S or B. As above Mosman Park (P) went around 1972 and the Valley Plant in Brisbane that used a B was gone by 1967.
Edited by user Friday, 15 November 2024 6:17:02 AM(UTC)  | Reason: Not specified
#6 Posted : Friday, 15 November 2024 6:03:49 AM(UTC)
Chassis is CHZ249xx
I can get a build timeframe from the chassis number and PSN, but not with digits missing.
bslater79 Offline
#7 Posted : Friday, 15 November 2024 10:09:37 AM(UTC)
bslater79
CHZ24903B
8M70LJH492112Z
Body : 492112B
#8 Posted : Friday, 15 November 2024 12:22:00 PM(UTC)
CHZ24903B
8M70LJH492112Z
Body : 492112B
Will have a look when I’m near my database later today or on the weekend.
Looks like I edited your post too, rather than quoting it a few posts above. Will fix it later.
Edited by user Friday, 15 November 2024 12:23:35 PM(UTC)  | Reason: Not specified
bslater79 Offline
#9 Posted : Friday, 15 November 2024 2:53:55 PM(UTC)
bslater79
Thanks HK1837 - so helpful as usual
#10 Posted : Friday, 15 November 2024 5:00:25 PM(UTC)
CHZ24903B
8M70LJH492112Z
Body : 492112B
June 1979. Just into ADR35 on commercials I think hence the CHZ (1/79 I think CHZ started on commercials).
Edited by user Friday, 15 November 2024 5:41:48 PM(UTC)  | Reason: Not specified
