castellan Offline
#1 Posted : Friday, 6 December 2024 10:14:25 AM(UTC)
castellan
I think my SL/R5000 Had mechanical linkage, when did they go to the cable ? LX or ? I think HJ were the start of cable 10/1974
#2 Posted : Friday, 6 December 2024 2:54:32 PM(UTC)
All LH had cable throttle. They were the first, then the HJ introduced the cable later that year.
Edited by user Friday, 6 December 2024 3:04:10 PM(UTC)  | Reason: Not specified
#3 Posted : Friday, 6 December 2024 3:25:59 PM(UTC)
That’s how you pick LH V8 (and HJ) intakes from HQ ones. The have an extra threaded hole for the cable throttle spring return bracket.
castellan Offline
#4 Posted : Saturday, 7 December 2024 11:18:39 AM(UTC)
castellan
1990 when I bought my L34 Torana and I thought it was the cable being the reason why I could not put the Holley on my HX sandman 5.0L.
I went to try and put the Holly on my HX but could not do it for some reason.
So I thought it may of been the Cable setup as to why.
Edited by user Saturday, 7 December 2024 11:19:45 AM(UTC)  | Reason: Not specified
#5 Posted : Saturday, 7 December 2024 11:25:53 AM(UTC)
Cable throttle would probably have been easier with a Holley than a HQ linkage. Getting the right throttle movement was the hardest bit. I always had trouble with converted 6cyl cars, people always seemed to use the 6cyl pedal arrangement, not change it to be as per a V8 car.
#6 Posted : Sunday, 8 December 2024 7:50:47 AM(UTC)
Was thanked: 40 time(s) in 39 post(s)
.. common problem with people doing 6/8cyl swaps on any Holden car (Holden thru to Commodore)
ALWAYS change the cabin pedal setup too
