HQ_SS_Andy Offline
#1 Posted : Sunday, 12 January 2025 2:29:09 PM(UTC)
HQ_SS_Andy
I'm in the process of replacing an automatic transmission with an 4-speed M20 in my HQ. It's a 253 V8.
It was originally manual.
Questions:
1. With the M20 and a 3.36 diff, does anyone know what colour the speedo driven gear should be ?
2. How does the wiring route for the reverse switch ? Under the carpet and then penetrating through the tunnel ? Or through the firewall and then running on the underside of the floor (like the speedo cable).
Thanks in advance.
Andrew.
HQ_SS_Andy Offline
#2 Posted : Sunday, 12 January 2025 2:31:05 PM(UTC)
HQ_SS_Andy
...I should add that it's a floor shift.
#3 Posted : Sunday, 12 January 2025 3:05:34 PM(UTC)
Originally Posted by: HQ_SS_Andy Go to Quoted Post
Questions:
The driven gear will depend on the tyre size, the closest will be a green (21 tooth) gear. If that is not correct you could try a white (20 tooth) gear or a dark blue (22 tooth) gear. Each tooth is worth around 5% (i.e. 5 kmh in 100 kmh).
The wiring runs under carpet, from the base of the steering column where it plugs into the 2-pin reverse light connector, down thru a grommet and hole in the floor pan, not far to the left of the floor-shift hole cut-out.
Dr Terry.
Edited by user Sunday, 12 January 2025 3:06:41 PM(UTC)  | Reason: spelling
HQ_SS_Andy on 12/01/2025(UTC)
HQ_SS_Andy Offline
#4 Posted : Sunday, 12 January 2025 3:22:23 PM(UTC)
HQ_SS_Andy
Thanks very much. Excellent info as usual Smile
#5 Posted : Sunday, 12 January 2025 6:37:30 PM(UTC)
Was thanked: 603 time(s) in 570 post(s)
Go looking in HQ to HZ M21 boxes for the driven gear, most of them were 3.36.
kevrev Offline
#6 Posted : Tuesday, 14 January 2025 6:57:57 AM(UTC)
kevrev
You might want to try this online speedo gear calculator, I've found it useful in the past
https://www.centauriaudi...tchc4878/speedocalc.html
Cheers Kev
 1 user thanked kevrev for this useful post.
HQ_SS_Andy on 14/01/2025(UTC)
HQ_SS_Andy Offline
#7 Posted : Tuesday, 14 January 2025 5:52:57 PM(UTC)
HQ_SS_Andy
That's really useful. Thanks Kevrev.
