Joined: 4/02/2025(UTC) Posts: 3 ![Australia Australia]() Location: Adelaide
Recently purchased a HZ and trying to understand the id break down. Below are the letters and numbers
General Motors Holdens Limited
8M60RKL469744Z
Model - HZWM60 Body - 469744-A Trim - 1930-67C Paint - 568-30521 Eng - L32 Trans - M40 RRAXLE - GV7
Holden HZ Cab Chassis
11-79 CHZ74522A
I do have the engine number somewhere.
Any help or advice would be greatly appreciated.
Thanks: 3 times Was thanked: 43 time(s) in 42 post(s)
Hi Jase, as you probably gathered you have a HZ one tonner from the Adelaide plant.
It was a factory 253 with trimatic auto.Diff ratio was 3.55.
Painted Palais white with tan trim.
Thank you
Do you know if all the number should match?
Hi Jase, The skinny tag matches the Body tag, both have the same number 469744 incorporated. The chassis number you have on the compliance plate should match the physical number stamped in the chassis near the steering box. The engine number will be completely different again, won't match the other numbers you have here, but might give some insight if its of the same era as numbers being issued in late '79 and possibly original to the car or definitely not if wrong era. Edited by user Wednesday, 5 February 2025 3:31:25 PM(UTC)
| Reason: Not specified
Thanks: 1 times Was thanked: 569 time(s) in 541 post(s)
Chassis number is consistent with the PSN of L469744. Looks to be pretty much stock HZ cab-chassis just optioned with 4.2L V8 and auto. It could possibly have had bucket seats but probably a bench and thus 3 seater. It was originally Palais White (1930) with Brown trim (67C) not Tan trim. |
