bazza30555 Offline
#1 Posted : Thursday, 6 February 2025 8:16:05 AM(UTC)
bazza30555
Hi, how do I remove the Boot Lock from a HK Holden.
Cheers Bazza.
#2 Posted : Thursday, 6 February 2025 7:07:54 PM(UTC)
Hi Bazza, I'm presuming it will be same as HT.
Open the boot up and directly under the lock look at the flat surface about an inch wide before the rubber. There is a plate about 2 inches long with screws in. This is actually the retainer for the lock. Might need a bit of a wriggle once the screws are out
bazza30555 Offline
#3 Posted : Friday, 7 February 2025 2:43:29 PM(UTC)
bazza30555
Thanks Sandaro,
I gathered that was the way to remove it. Tried to pry it out but it didn't seem to want to move. Was just checking to make sure I was doing it right.
bazza30555 Offline
#4 Posted : Monday, 10 February 2025 6:30:16 PM(UTC)
bazza30555
l managed to remove the key barrel and the circular spring was broken. Can they be repaired or do l have to change it. Are new one's available.
Chris W Offline
#5 Posted : Thursday, 13 February 2025 4:57:18 PM(UTC)
Chris W
You can get a new lock from Rare Spares
bazza30555 Offline
#6 Posted : Friday, 14 February 2025 11:18:18 PM(UTC)
bazza30555
Was hoping to repair existing one so all locks matched. Thanks Chris.
#7 Posted : Saturday, 15 February 2025 7:18:41 PM(UTC)
I wasn't sure what you mean by the circular spring. Is that part of the retainer or internal in the lock? If you do need a new barrel a locksmith can convert one to suit your current keys.
bazza30555 Offline
#8 Posted : Sunday, 16 February 2025 8:36:57 AM(UTC)
bazza30555
The long flat piece that operates the boot latch had fallen out of the end of the barrel and I had to remove the back seat to get the boot open.
Can't work out what held the long piece in the end of the barrel and I presume the circular spring on the end of the barrel returned it to the locked position.
If anyone has a close up pic of an original lock it would be handy.
