Joined: 25/12/2006(UTC) Posts: 49  ![Australia Australia]() Location: In the shed Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Does anybody know the differences in 4cyl vs 6cyl trimatics? I bought one on the weekend for a future project, it has a 6cyl bellousing but has gemini written on the case with wreckers pen. The guy i bought it from said it was in a 6 cyl commo. Hopefully it will be fine behind a std 186
What are the 2 letters on the ID plate on the side of the housing?
Also which side of the box is the selector?
Dr Terry |
Its a drivers side lever and the tag has a D then a 7 digit number
Thanks: 1 times Was thanked: 634 time(s) in 596 post(s)
You want the 2 digit number in much bigger font, the big letters (HT) in the attached link. What you are quoting is the calibration and the serial number https://www.uniquecarsan...ntification_transmission |
The riveted tag is polished clean, all that is left is the stamped D and 1115954
And OL 405 near the modulator
