Joined: 24/02/2025(UTC) Posts: 12 ![Australia Australia]() Location: perth Thanks: 6 times
hi all, does anyone have a lead on where i can get a sump for 350 sbc with 2pce rear main and lh dipstick into hg? all i can find is the extra large capacity sumps. just looking for a 5 quart sump. currently has what i believe to be a 72 impala sump on it. will this or a HQ sump work?, or will i have to cut and shut it? draglink steering not rack and pinion. cheers Hilly Edited by user Wednesday, 5 March 2025 11:55:47 PM(UTC)
| Reason: Not specified
Thanks: 1 times Was thanked: 632 time(s) in 594 post(s)
You'll need an original or aftermarket sump. Heaps on Ebay or look on Gumtree or Marketplace for used originals. Lots of used ones out there, tens of thousands of them off HK. https://www.ebay.com.au/...JNKXXHYG65XHNJSVK41R8FCK |
ive just bought 2x sumps for $80ea, ill try one rear type, and if that wont work i'll make a center type.
A normal Chevy dump won’t work. Just Google HK-HG SBC sump and you can see what one looks like. You need the pickup too. |
yeah i'm going to have to cut and shut it, i'll push it as far to the rear as i can. i bought a moroso pickup that you can make your own and may have to look at another pickup if i end up going center style. i'll be able to sort something out and make a pan out of the 2 new ones.
