Joined: 25/12/2006(UTC) Posts: 40  ![Australia Australia]() Location: In the shed Thanks: 3 times
Are HK and HQ disc stub axles the same? I want to use a pr of hk disc stubs on a hq im building. Are they interchangable? Thanks
Thanks: 3 times Was thanked: 39 time(s) in 38 post(s)
Apparently they are. Just have to swap sides because of location of steering arms.
Thanks: 1 times Was thanked: 527 time(s) in 503 post(s)
Exactly the same part number, just swapped side to side. Only different thing is cab-chassis are heat treated. |
