Joined: 25/12/2006(UTC) Posts: 49  ![Australia Australia]() Location: In the shed Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Are HK and HQ disc stub axles the same? I want to use a pr of hk disc stubs on a hq im building. Are they interchangable? Thanks
Thanks: 3 times Was thanked: 45 time(s) in 44 post(s)
Apparently they are. Just have to swap sides because of location of steering arms.
Thanks: 1 times Was thanked: 618 time(s) in 584 post(s)
Exactly the same part number, just swapped side to side. Only different thing is cab-chassis are heat treated. |
