justgm Offline
#1 Posted : Saturday, 2 August 2025 4:19:21 PM(UTC)
justgm
HI all, I am still looking for a Tech-1 .....Anyone ? Thanks Mark.
stevo Offline
#2 Posted : Sunday, 3 August 2025 5:40:27 AM(UTC)
stevo
I gotta ask what does a tech-1 do? never seen one, what does a tech-1 do that a paper clip and counting the number of times the light flashes can't.
Why do you need one?
GM bleed us dry and run away.
#3 Posted : Sunday, 3 August 2025 2:23:06 PM(UTC)
This is the difference between a proper scanner & a simple code reader. Scanners are used to program keys, recalibrate gauges, update software, operate ABS valves etc. etc. whereas code readers don't usually do much more than read (& maybe erase) fault codes.
The Tech-1 was the predecessor to the Tech-2. From memory Tech-1 was used for VL to VS ((OBD1) & Tech-2 was used for VT onwards (OBD2).
Tech-1s are very thin on the ground these days & so are the various cartridges & adaptors required for the different systems used back in those days.
justgm Offline
#4 Posted : Monday, 4 August 2025 6:33:59 PM(UTC)
justgm
Yes correct, Tech -1 is a very good diagnostic tool . I can get one out of USA but you need the Holden/Opel programs to make it work on our cars .
stevo Offline
#5 Posted : Tuesday, 5 August 2025 5:47:42 AM(UTC)
stevo
Can I ask what are you working on? Very few VN-VP have abs they dont have transponder chips in the key, I made one of these once I've never used it even when I drove a vp. https://www.techedge.com...cle/aldl160/vn_aldl.htm I once had a vq statesman I don't remember using it when I did the brakes on it. What gauges on a Vn-Vp commodore can be calibrated?
Edited by user Tuesday, 5 August 2025 6:38:37 AM(UTC)  | Reason: Not specified
#6 Posted : Tuesday, 5 August 2025 8:40:49 AM(UTC)
Yes, you are correct with respect to VN-VP ABS & gauges etc. but with Tech-1 on the older cars they are very good with active data. In other words direct reading of things like coolant temp, throttle %, idle motor steps, idle RPM & various other bits & bobs make set-up easier.
#7 Posted : Tuesday, 5 August 2025 4:44:10 PM(UTC)
I found these in my shed. No modules though. This was in a box full of stuff I got from Wyong Motors I think. Or possibly the old Young and Green in Belmont NSW. I have never used it on a car as I have no modules, and I have never seen any for sale either.
These guys say they have the Tech1A units for sale in limited quantities.
Edited by user Tuesday, 5 August 2025 4:47:20 PM(UTC)  | Reason: Not specified
justgm Offline
#8 Posted : Tuesday, 5 August 2025 6:29:43 PM(UTC)
justgm
I have a couple of "modules" to suit Tech-1 . Do you want to sell it ? Thanks Mark.
antelopeslr5000 Offline
#9 Posted : Friday, 3 October 2025 4:04:33 PM(UTC)
antelopeslr5000
As far as I’m aware there are 4 main cartridges (and maybe some variants) used with the Tech 1 for Holden Commodores.
These are:
  • Holden’s 1988 ECM Cartridge (Used for VN & VP ECM’s)
  • 1991 OEM Dealer Body Cartridge (For VP & VQ Series II vehicles equipped with the Bosch Body Control Module)
  • VR Systems OEM Dealer V1.0 Cartridge
  • VS/T4 Systems OEM Dealer V1.0 Cartridge
Variants of these cartridges were available for purchase by independent, non-Holden Dealership garages/mechanics that didn’t include access to the security system of the vehicle (for example, the inability to program a key FOB/Remote).
Edited by user Sunday, 5 October 2025 9:34:15 AM(UTC)  | Reason: Spellling
