Taztiger4 Offline
#1 Posted : Wednesday, 20 August 2025 10:27:04 PM(UTC)
Taztiger4
Hi, need to replace my engine driven fan, whats the best option flex or viscous ? not intersted in thermo options.
TIA
#2 Posted : Saturday, 23 August 2025 6:30:01 PM(UTC)
TIA
the original factory one .....
Taztiger4 Offline
#3 Posted : Monday, 25 August 2025 10:19:03 PM(UTC)
Taztiger4
TIA
Ok, the engine driven fixed fan it is then, thanks
#4 Posted : Wednesday, 27 August 2025 12:52:48 PM(UTC)
Obviously viscous will save you wasted hp when travelling at road speed as it will cut out. The non viscous will constantly rob you of hp.
They should both shift the same amount of air if they are the same size.
The shroud probably is going to make both of them work better.
 1 user thanked wbute for this useful post.
Taztiger4 on 2/09/2025(UTC)
