Joined: 30/04/2005(UTC) Posts: 485  ![New Zealand New Zealand]() Was thanked: 16 time(s) in 15 post(s)
HI all, I am still looking for a Tech-1 .....Anyone ? Thanks Mark. |
life is good in "Wine & Holden Marlborough " |
Thanks: 1 times Was thanked: 5 time(s) in 5 post(s)
I gotta ask what does a tech-1 do? never seen one, what does a tech-1 do that a paper clip and counting the number of times the light flashes can't. Why do you need one? |
GM bleed us dry and run away. |
Originally Posted by: stevo  I gotta ask what does a tech-1 do? never seen one, what does a tech-1 do that a paper clip and counting the number of times the light flashes can't. Why do you need one? This is the difference between a proper scanner & a simple code reader. Scanners are used to program keys, recalibrate gauges, update software, operate ABS valves etc. etc. whereas code readers don't usually do much more than read (& maybe erase) fault codes. The Tech-1 was the predecessor to the Tech-2. From memory Tech-1 was used for VL to VS ((OBD1) & Tech-2 was used for VT onwards (OBD2). Tech-1s are very thin on the ground these days & so are the various cartridges & adaptors required for the different systems used back in those days. Dr Terry |
Yes correct, Tech -1 is a very good diagnostic tool . I can get one out of USA but you need the Holden/Opel programs to make it work on our cars . |
Can I ask what are you working on? Very few VN-VP have abs they dont have transponder chips in the key, I made one of these once I've never used it even when I drove a vp. https://www.techedge.com...cle/aldl160/vn_aldl.htm I once had a vq statesman I don't remember using it when I did the brakes on it. What gauges on a Vn-Vp commodore can be calibrated? Edited by user Tuesday, 5 August 2025 6:38:37 AM(UTC)
| Reason: Not specified |
Originally Posted by: stevo  Can I ask what are you working on? Very few VN-VP have abs they dont have transponder chips in the key, I made one of these once I've never used it even when I drove a vp. https://www.techedge.com...cle/aldl160/vn_aldl.htm I once had a vq statesman I don't remember using it when I did the brakes on it. What gauges on a Vn-Vp commodore can be calibrated? Yes, you are correct with respect to VN-VP ABS & gauges etc. but with Tech-1 on the older cars they are very good with active data. In other words direct reading of things like coolant temp, throttle %, idle motor steps, idle RPM & various other bits & bobs make set-up easier. Dr Terry |
I have a couple of "modules" to suit Tech-1 . Do you want to sell it ? Thanks Mark. |
Joined: 3/10/2025(UTC) Posts: 1 ![Australia Australia]() Location: Queensland
As far as I’m aware there are 4 main cartridges (and maybe some variants) used with the Tech 1 for Holden Commodores. These are: - Holden’s 1988 ECM Cartridge (Used for VN & VP ECM’s)
- 1991 OEM Dealer Body Cartridge (For VP & VQ Series II vehicles equipped with the Bosch Body Control Module)
- VR Systems OEM Dealer V1.0 Cartridge
- VS/T4 Systems OEM Dealer V1.0 Cartridge
Variants of these cartridges were available for purchase by independent, non-Holden Dealership garages/mechanics that didn’t include access to the security system of the vehicle (for example, the inability to program a key FOB/Remote).  Edited by user Sunday, 5 October 2025 9:34:15 AM(UTC)
| Reason: Spellling
