7 Pages«<567
castellan Offline
#121 Posted : Friday, 2 October 2015 9:02:05 PM(UTC)
castellan
Originally Posted by: gm5735 Go to Quoted Post
I just checked, I think it was 10lb per cubic inch hence for the projected curb weight of the HK GTS327 of 3250lb the 327 just fit. This was an area that received a reasonable level scrutiny from GM. There was no need to use the L30 327 as the HK GTS327 was never going to be outclassed by the XT's 302 in Series Production and in the ATCC they could run whatever 327 engine they liked.
The other magical limit as Geoff says was 10lb per hp, HK was just over 13lb/hp and HT was to be just over 11lb/hp. This wasn't a corporate ruling as such, but 10lb/hp was the benchmark for very high performance vehicles.
By 1969 it changed to maximum of 400ci and this is how the HT fit into the GM rules.
I have read that the 1hp/10lbs rule was "ironclad corporate policy" in several places, but obviously it is hard to prove based on evidence from GM, as there probably isn't any.
Given the sort of power vs capacity outputs of the time of around 1HP per cubic inch, it amounts to nearly the same thing.
Look at the LC Torana as one example of power to weight type of idea as a HK got a 161 and 186 and a 186S, now the Torana got this funny little 138 and the 161 and then a 161S and then the rocket ship 186 XU-1.
The thing is this little 138 red motor why make that, it must have to do with some power to weight principle and she is still their in the LJ but gone in the bigger LH.
Same thing with the big 202, the HQ weight called for the big 202 and 161 became a 173.
This proves that GMH use some type of figures that justify what they do.
Look at the 4 CYL Torana's 1.2L 1.6L in LC-J and 1.3L 1.76L in the TA and then only the big Opel 1.9L power house in the LH would do.
castellan Offline
#122 Posted : Friday, 2 October 2015 9:20:15 PM(UTC)
castellan
Originally Posted by: detective Go to Quoted Post
...a bit off topic....back in the day about 1980 when i was a kid, I was driving the HQ GTS350 coupe in earnest...fanging around, going fast in the wet around bends, dragging motorbikes from the lights etc., etc....
...an ol' mate had an XW auto with Cleveland...(about a 1970 model i guess?). The difference between the two cars was profound. The 350 was like a greyhound in its agility and acceleration, whereas the GT was like a bloody great draught horse...tons of torque, that clunky Detroit locker and an extremely solid feel to the whole thing...
....just an observation, but his interior was black, and mine is white with houndstooth inserts ....even that made them feel so different !!
The thing with the automatic 351C is that they came with such a high 2.75 ratio diff and that makes them feel more like you say.
I knew of a HQ 350 Statesman with 2.78 diff and stock single exhaust it was like a barge.
I always hear people bagging how HQ handled, sure they understeered but set up right with good shocks they were not bad, better than the Falcons of them years with that garbage leaf sprung rear end.
#123 Posted : Friday, 2 October 2015 10:31:21 PM(UTC)
Was thanked: 222 time(s) in 201 post(s)
Originally Posted by: castellan Go to Quoted Post
[quote=detective;166053]I always hear people bagging how HQ handled, sure they understeered but set up right with good shocks they were not bad, better than the Falcons of them years with that garbage leaf sprung rear end.
Bravo, the most sensible comment I've heard in years.
gm5735 Offline
#124 Posted : Friday, 2 October 2015 11:22:47 PM(UTC)
gm5735
https://youtu.be/rRUI3kbN8oc
Worth a look if you haven't seen it. Watch the Falcons exiting Mcphillamy Park at 3:24 onwards, and wonder no more why they had excessive tyre wear.
Edited by user Friday, 2 October 2015 11:25:40 PM(UTC)  | Reason: Not specified
#125 Posted : Saturday, 3 October 2015 7:41:22 AM(UTC)
I spoke to Harry Firth about that several years ago. He said the HO's achilles heel was the fact that they had 164 litres of fuel beautifully positioned about 3-feet behind the rear axle, acting like a pendulum when cornering.
#126 Posted : Saturday, 3 October 2015 7:46:15 AM(UTC)
Was thanked: 561 time(s) in 535 post(s)
I would have said the biggest problem was the Geoghegans and Al Turner letting old Harry go, and their biggest asset was Bruce McPhee.
gm5735 Offline
#127 Posted : Saturday, 3 October 2015 2:35:28 PM(UTC)
gm5735
That makes sense. That, lots of squat off corners, and a Detroit locker made them an "interesting" thing to drive on the limit, particularly with corner exit understeer. They need to be pretty straight before you boot them.
The 25 gallon Monaro tanks are better placed from a fore and aft standpoint, but the extra height above the roll centre means everything isn't beer and skittles. There is a baffle in the tank, which usually breaks off after a while since it is spot welded into the tank on two faces only, but you certainly feel the fuel slosh when you turn in.
That, and the likelihood of emptying the tank contents out the filler neck in right hand corners, since the filler neck is submerged with more than 80 litres in the tank. At least the tanks don't stay full for very long.
FE327CHEVY Offline
#128 Posted : Thursday, 10 December 2015 6:05:48 PM(UTC)
FE327CHEVY
I been talking to HK1837 and just joined the forum.
Some points I wanted to make/share that I have read is that I believe that in 1966' Flint stored a years supply of four barrel intakes for camaro etc and hence I believe that this might have been sent elsewhere because it must have been replaced on the same site. So Saginaw might have supplied early year 67 engine four barrel intakes to McKinon until tooling went elsewhere. I can't prove this but a survey was done by a car club cos of judging requirements for intakes etc.
Also I think I got a truck 327 motor, which was called a "high torque 327". I think I got one of these. It only has a number 15393 k#### on the stamp pad. Anyway I found it interesting cos it had blue valve covers, which were green in 66 models, but I'm not sure if the c10 to c30 Aussie trucks kept green or went to grey like the states? Canadian ones had script on pre 1966 and plain after 1966. I am wondering if anyone has had or seen many original 327 torque engines.
See mine has thick valve stems and double valve springs. Here's the strong 5477 forged crank too.
Any info would be appreciated. Plenty of vins on Canadian trucks have ce1539 as part of the numbers, with 1 being tonnage, 5 cab chassis, 3 wheelbase and 9 indicating stake/flat tray. My 3 looks to be stamped different to the other ones. I also entertained the idea that it could have been a police car Biscayne replacement engine for a 6cyl with the "153" model code being Biscayne and the "39" super sport but why a low compression for a police car lol.
Just thought I'd share cos its obviously low volume McKinnon.
The intake and engine were cast at Flint we think, McKinnon 75cc heads.
Edited by user Thursday, 10 December 2015 6:08:01 PM(UTC)  | Reason: Not specified
FE327CHEVY Offline
#129 Posted : Tuesday, 7 October 2025 11:04:09 PM(UTC)
FE327CHEVY
For younger people or newbies RE: Parisienne 327 engines, So the 240hp low compression 327 was called an "Astro Flame".
So from what I can gather there were some plain, but blue valve cover engines with the Rochester quadrajet and the Tonawanda 4 barrel intake in 1967 but with Mckinnon block and heads with the February 1967 date. I gather the 230hp 75cc headed (with exhaust valve rotators and big water pump like my 1967 engine) would have been the same actual engine configuration but the Carter carb may have made it 230hp. Any comments welcome about the brochures with 230hp version.
https://xr793.com/wp-con...ntiac-Parisienne-AUS.pdf
Edited by user Tuesday, 7 October 2025 11:05:04 PM(UTC)  | Reason: Not specified
#130 Posted : Wednesday, 8 October 2025 11:28:04 AM(UTC)
I think they ran like this for the regular fuel 4BBL 327:
1966 230hp 8.55:1 with 75cc chamber heads (rounded to 8.75:1), fitted with Rochester 4GC.
1967 240hp, same as above but fitted with Quadrajet.
1968 250hp, heads changed to the new 69cc 307 heads for 9:1 compression, otherwise the same as 1967. Compression incorrectly quoted, cannot be 8.75:1 as heads have smaller chambers. Also 307 with same heads is actually 8.75:1 with same stroke and flat tops, 327 has to be higher due to extra cylinder volume.
1969 235hp, same spec heads as 1968 just with accessory holes, compression correctly quoted as 9:1. 15hp loss due to the use of the large 2BBL carb.
The Canadian 327 in late HK is the same fundamental specification as a 1967 regular fuel 327.
7 Pages«<567
