Fastlane
Holden Forums
Holden Technical Talk
vc 1 inch master cylinder rebuild
Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
finally getting closer to getting the vc on the road, have rebuilt the master cylinder but the brakes are crap even though ive bled them several times. the pedal feel is a bit mushy. ive retraced my steps on the rebuild and referenced the gregorys manual. in it says when removing the cup seals off the pistons, first cut the seal retainers. ive done this but when ive replaced the cups seals there was no replacement retainers in the rebuild kit. are they even used anymore? of all the kits ive seen there are no replacement plastic retainers whats the go here?
Joined: 6/07/2019(UTC) Posts: 462 ![Australia Australia]() Location: bayside Melbourne Thanks: 298 times Was thanked: 39 time(s) in 38 post(s)
Originally Posted by: holden05  finally getting closer to getting the vc on the road, have rebuilt the master cylinder but the brakes are crap even though ive bled them several times. the pedal feel is a bit mushy. ive retraced my steps on the rebuild and referenced the gregorys manual. in it says when removing the cup seals off the pistons, first cut the seal retainers. ive done this but when ive replaced the cups seals there was no replacement retainers in the rebuild kit. are they even used anymore? of all the kits ive seen there are no replacement plastic retainers whats the go here? whose kit you using? The PBR Bosch kits I have used in the past have the retainers maybe try an auto brake specialist |
Not sure if the brand but I bought the kit from a local brake shop Would not having them installed be giving me the issue of having rubbish stopping power?
Originally Posted by: holden05  Not sure if the brand but I bought the kit from a local brake shop Would not having them installed be giving me the issue of having rubbish stopping power? .. not installed??? wow! NO stopping power from that master! |
spoke to the shop id got the kit from, they contacted their supplied and we told the retainers wernt used anymore
Originally Posted by: holden05  spoke to the shop id got the kit from, they contacted their supplied and we told the retainers wernt used anymore run.. run away quickly from any supplier/manufacturer making a kit DIFFERENT from the original manufacturers'specs especially when brakes are concerned! ps.. what is holding the cups in place? Answer ... nothing! Its a wonder you have any brakes at all |
Originally Posted by: Smitty2  Originally Posted by: holden05  spoke to the shop id got the kit from, they contacted their supplied and we told the retainers wernt used anymore run.. run away quickly from any supplier/manufacturer making a kit DIFFERENT from the original manufacturers'specs especially when brakes are concerned! ps.. what is holding the cups in place? Answer ... nothing! Its a wonder you have any brakes at all thats about right, im struggling to find anybody thats has a rebuild kit with the seal retainers recommend anybody?
Fastlane
Holden Forums
