greenhj Offline
#1 Posted : Tuesday, 10 February 2026 10:13:22 AM(UTC)
greenhj
Was thanked: 15 time(s) in 13 post(s)
Hi guys,
My son bought a VS V8 ute.
Randomly and annoyingly, it seems to trigger VATS while driving (my assumption) due to a brief flash of the security LED and CEL, which you wouldnt even notice unless you are looking at it, dash cluster dropping out (which is very noticable) and some weirdness to the engine (presumably fuel cut)
Along with code 31 after a paperclipping to the ALDL port.
We changed the keyfob and tweaked the slip rings but its still happening.
Is there anything else worth checking before I ragequit and pay a Man to turn off VATS as a test, and probably never turn it back on?
#2 Posted : Wednesday, 11 February 2026 5:15:41 PM(UTC)
Originally Posted by: greenhj Go to Quoted Post
Hi guys,
SIII... VS V8? and any other codes being thrown? you got a scanner you can check with?
also you had a look at both the PCM and BCM in the car to see if any previous possessor
of this set of wheels has had a hack at the wiring/wiring connector to these modules?
people think a quick snip of a coupla bits of wire will disable it (it does not!)
greenhj Offline
#3 Posted : Thursday, 12 February 2026 8:44:47 PM(UTC)
greenhj
Im not sure if its series 3, built 8/98 if that helps.
I havent had time to go properly digging around under the dash but a near 30yr old car is bound to have some shenanigans if not just wear and tear.
I dont have anything capable of reading ALDL but have been researching half reasonable scantools that will do his car and hopefully my VZ for a bit more in depth analysis when fault finding but I believe there isn't any way to turn off the VATS without pulling the eeprom and having the right software so if I can find someone in SE melbourne who has the equipment and can do it, that's where I'll go.
#4 Posted : Friday, 13 February 2026 3:56:58 PM(UTC)
Was thanked: 616 time(s) in 583 post(s)
8/98 is VSIII. It should still have the flat tappet VS 5.0L. These only had a single O2 sensor and a rectangular throttle body cover.
8D11PCH2 Offline
#5 Posted: : Saturday, 14 February 2026 8:07:22 AM(UTC)
8D11PCH2
Take a look at the $325.00 Vident i400au (with Holden software) single brand bi directional scan tool from A-Z Scanners.
I bought the Vident i800 pro which can do everything the i400au for Holden can do + 70 other brands/models.
greenhj Offline
#6 Posted : Saturday, 14 February 2026 9:27:07 AM(UTC)
greenhj
Does anyone have a wiring diagram for the VATS circuit so I've got something to chase in the car?
greenhj Offline
#7 Posted : Sunday, 15 February 2026 6:43:35 PM(UTC)
greenhj
Did some fiddling, cleaned the body earth, engine earth, checked the BCM plugs and pulled the covers off for a looksee at the ignition barrel, gave the slip rings a tickle with fine emery.
Nothing to see here.
We went for a quick half hour drive to the supermarket, of course because I was in the car it didn't do anything untoward. He'll take it to trade school tomorrow which is 70 odd K's away and it will do it 5 times haha.
senatorjohn Offline
#8 Posted : Wednesday, 18 February 2026 8:18:19 PM(UTC)
senatorjohn
[quote=greenhj;188871]Im not sure if its series 3, built 8/98 if that helps.
[Just had VATS removed from a VF ECM by C&M Performance in Melbourne. /quote]
greenhj Offline
#9 Posted : Friday, 20 February 2026 6:30:02 AM(UTC)
greenhj
4 days and 600 odd k's later and it hasnt happened since. I did run a meter between the plug to the bcm and the slip rings and found "odd spots" where the resistance was higher in some areas, correlating with what everyone said ever about making sure they were properly clean.
The emery may have sorted it.
Probably going to go down the rabbit hole of delco tuning anyway because its handy to have access and we will build a nice engine for it eventually and I have a dirty old 808 delco I will likely use on a boring 202 at some point.
When did 30 year old cars get so complicated? Wasn't like that when my first car was only 20 years old but there aint much in a HJ kingswood I suppose haha
mmazz30 Offline
#10 Posted : Monday, 23 February 2026 9:51:40 PM(UTC)
mmazz30
Go on the pcmhacking.net site for the tuning side of stuff.
The S3 stuff is/was a pain as there wasn't a proper binary/definition/adx file that worked well when I looked a couple of years ago.
It may have been updated....not sure.
Guest (5)
