holden05 Offline
#1 Posted : Friday, 27 March 2026 7:35:50 PM(UTC)
holden05
I’ve just recieved my master cylinder back from Burt bros. When I asked about bench bleeding they said there was no need. “Just mount it up and bleed it like normal”
Does this sound right?
#2 Posted : Saturday, 28 March 2026 9:06:49 AM(UTC)
Was thanked: 235 time(s) in 209 post(s)
It will work either way.
I prefer to bench bleed first. It is less messy & you know it is fully bled before fitting. You will then only need 1 or 2 pumps after fitting, unless of course you want to fully bleed to the wheels.
holden05 Offline
#3 Posted : Saturday, 28 March 2026 9:26:33 AM(UTC)
holden05
Hi Dr Terry
I was intending in bolting up “dry” and vacuum power bleeding the whole system at each wheel. Burt’s are saying that as it’s a non pressure line . Does my method sound ok
