2 Pages<12
#21 Posted : Friday, 10 July 2026 7:37:18 AM(UTC)
Was thanked: 634 time(s) in 596 post(s)
Originally Posted by: DeezalHk68 Go to Quoted Post
Hk1837 tried to pm you but may not have worked,
No to Salisbury, has a 9 inch, was going down a different path, will run 327 for now - extremely lucky chances of finding oe engine are super slim-to nil, but open to building 307 down the track, have original p/glide. Am open to Salisbury as plans look as though they are certainly changing.
I wouldn't get too carried away driveline, not worth it without the original engine plus boring. I own the oldest known surviving V8 HK GTS, its original engine has gone so I ripped out the Powerglide, banjo and the whole front end. Car is repaired and painted as per original but its now got a 9" and a Rodtech front end with power steering. Giving it an injected 305 with TH350C to get it sorted and later will get a stroked 350 (377ci). All changeable back but no interest for me to do that. Don't waste your time on a 10-bolt if its not there now, will cost too much. I'd use the 9" but if you want a Salisbury and it was originally a Salisbury (as in has the clearance hump for a 12-bolt) buy a 12-bolt. You will never break it. Stick with the 327 unless an original Pagewood HK 307 falls into your lap, not worth the effort.
WagonDan Offline
#22 Posted : Friday, 10 July 2026 11:01:27 AM(UTC)
WagonDan
That's a pretty big statement to make 🤔
Shouldn't we be trying to preserve these vehicles as much as we can, where possible?
Especially a vehicle with interesting options or additions.
If we can count the amount of known Warrigal Black HK Coupes on 1 hand, I'd say thats a vehicle worth trying to preserve 👌
#23 Posted : Friday, 10 July 2026 12:13:37 PM(UTC)
Preserve if they are original. Once they are heavily changed, lost their engines etc. I cannot see the point. Especially on a lower spec car, its a GTS not a GTS327. As I said make it look original exterior and inside, but there is no good reason to make it original mechanically if you can do it without affecting the integrity of the car. I'm not promoting making it heavily modified like an LS, just bolt in stuff like engine, box, diff, steering and brakes. The amount of $ you'd spend trying to make it all original 307, Powerglide and 10-bolt would cost more than having a nice 327 or 350, 3spd auto and 9" with HQ brakes. That is the track I've taken with my HK GTS. It has the most original HK driveline in it you've ever seen from a totally original radiator, 307, Powerglide and banjo plus original exhaust. But none of it is original to the car, so why put up with it? The whole driveline came out of a mint HK Brougham with maybe 25,000 miles on it.
WagonDan Offline
#24 Posted : Friday, 10 July 2026 1:10:23 PM(UTC)
WagonDan
I suppose there are different opinions of "original".
A car can have its original driveline, as in fitted on the assembly line.
Or, it can be restored to original specification but may be missing its day 1 fitted components.
I certainly do not consider an 80737 to be a "lower spec" car.
Sure it may not have the big boy Yankee doodle engine of the 81837, but its no Belmont either....That would be the 80337 of the HK range.
It's also a very different scene here in New Zealand.
We can go to a months worth of local carshows here in Auckland, with a population of 1.5million and not see a single HK-T-G Coupe at any of those shows.
When we do see one out for an event, its quite a spectacle and draws alot of attention.
It makes us appreciate the rare/different cars that much more when we do see them, especially if they are reasonably close to day 1 specification.
DeezalHk68 Offline
#25 Posted : Friday, 10 July 2026 3:54:12 PM(UTC)
DeezalHk68
Hey Wagon Dan/HK1837 , been watching and appreciate the differing views, totally seeing both sides, the purist in me says Wagon Dan all the way, and my right foot at full throttle says HK1837 my thoughts on where i was going 5 days ago and now today couldnt be more different, will certainly be going factory black and the 14x interior, 0bvioudly black will require a lot of panel work , would like to go manual transmission, have a 327 so will use that, would b good over time to accumulate diff and 307 engine / rebuilt powerglide, all bolt in and in years to come if sold or what have you someone or next care taker can pic his poison,
Ask me tomorrow will be different again, Dio mio,
Certainly appreciate you both🙌🙌
#26 Posted : Friday, 10 July 2026 4:30:01 PM(UTC)
It’s your car and your choice. I agree with the keeping the original driveline on a pallet and if/when you sell it the buyer can choose.
I’ve had my eyes out for a mint original 6cyl HK-HG ute. I’ll do the same thing, 6cyl driveline will come out and go on a pallet if it’s original, otherwise in the scrap bin. It would get an injected VN-VS engine top end on one of the old HT-HG 308 blocks I have here with either column shift 3spd or Trimatic and an old 9” I have here.
DeezalHk68 Offline
#27 Posted : Friday, 24 July 2026 9:23:00 AM(UTC)
DeezalHk68
Hey hk1837 if you are watching,
Hopefully can do this on forum
What does engine 30712374k1023
Would you know what it is out of
Monaro / kingswood /premier?
Regards
Deezal
#28 Posted : Friday, 24 July 2026 10:28:06 AM(UTC)
Regards
Deezal
Its an auto engine out of Belmont (ute, van, wagon, sedan), Kingswood (ute, wagon sedan) or Premier (sedan, wagon) assembled at Pagewood mid to late June 1968. At a pinch it may be out of a very early Pagewood Monaro but too early for a Brougham or GTS. Its out of the same batch of engines used in the first Pagewood GTS's and Broughams (23rd and 24th October 1967 engine assembly) but the GMH number puts it too early for those.
DeezalHk68 Offline
#29 Posted : Friday, 24 July 2026 10:37:34 AM(UTC)
DeezalHk68
Thanks hk1837 you are a legend, much appreciated🙌
Guest (6)
2 Pages<12
