paul Guthrie Offline
#1 Posted : Saturday, 25 July 2026 10:26:24 PM(UTC)
paul Guthrie
Thailand
HI can anyone please help me identify this car , Its a statesman with the body number stamped on the drain rail on the cowl
HXO 7123 81469 XU7 0251
and chassis rail 0251
The tags and engine are missing which is common in Thailand
It has factory air con factory power steering factory electric windows factory tinted glass bucket seats with black plastic winders T bar auto holden hub caps , black pearl GTS dash wood grain in other areas
#2 Posted : Sunday, 26 July 2026 9:40:47 AM(UTC)
Its an 81469 XU7 which in HQ was called Chevrolet 350. Sold in Australia to consulates and also sent overseas to NZ and South Africa at least, plus probably Malaysia, Thailand etc. Sales used 84469 coding. But if its a later body, they were also sold in Malaysia with 3300 and 4sps manual, nit sure if they also used the XU7 coding but should be 8WS69 not 81469 model. Was it a HQ?
#3 Posted : Sunday, 26 July 2026 11:09:36 AM(UTC)
paul Guthrie
Thailand
Yeah the car is in Thailand and its a HQ the 350 engine and gearbox is missing but some one has replaced it with a 308 auto im pretty sure the codes read 81469 XU7
Is there any way to find trim and paint with tags missing i asked HHS and they said they cant if so can i get new tags done?
The 308 has the engine code QT 516 303 but the numbers are not in a line and looks hand stamped , was this done in over seas markets or is the number just mage up? I have photos but i dont know how to attach them here im a bit shit with computers thank you
#4 Posted : Sunday, 26 July 2026 1:07:43 PM(UTC)
81469 XU7 is the correct internal GMH model and PO code for it. The cars assembled in Australia had an 84469 sales code on the BODY ID tag so its obviously not Australian assembled. QT516303 is a HQ number, no idea where they would have got the number from unless it was originally on the block
You can post photos here. You have to upload images to an album, create the album first by clicking on your username and then CREATE ALBUM. Upload the images.
Then EDIT one of your posts, and click un the icon above the edit box with the double mountains, it says ADD ALBUM IMAGE when you hover over it.
It would never had tags on it like an Australian car showing paint and trim. What is on it are what the Malaysian Assembly plant would have put on it.
#5 Posted : Sunday, 26 July 2026 7:38:33 PM(UTC)
paul Guthrie
Thailand
Hi I tried to create that file and it said I can’t upload j peg files so I then renamed the files and tried again and it said this
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Web.HttpException: Maximum request length exceeded.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
Is there any email address I can send to or another way
Thank you sorry I did say I was shot with computers they done seem to like me :)
